Question about Toshiba Computers & Internet
I am fixing a laptop for a friend that has an onboard wireless card. All the drivers are installed ok and I can access other PCs and the internet with a ethernet wired connection. If I try to configure a wireless connection, I get a "wireless adapter not connected" message. I see that someone had reversed the black and white connectors on the card. Black is MAIN and white is AUX (am I right). My question is, by reversing the connections, would that had made the card U/S?
    Novelist:
  • 217 Answers
This is difficult to answer. Most of these wireless cards plug into a multi- conductor socket on the board. The nly external connections would be the antenna's and there are usually two. These are a very small diameter cable that terminate in a small, flat connector that is about an 1/8 of an inch in diameter. If these get switched, then there shouldn't be a problem. If these are power connectors, then the card may be damaged.
If would go to control panel, system, and devices (or hardware) and see what comes up for the wireless adapter. The chances are good the there is a caution indicated for this device, which usually means that the driver is incorrect. Try completely unloading it, and then let Windows search the net for a new one.
Posted on Dec 07, 2014
  • Clive Halliday
    Clive Halliday Dec 07, 2014
    No cautions or exclamation marks in device manager. Already tried reinstalling the drivers. Just connected via a Netgear USB wireless dongle so I guess the onboard card has gone west.
Wheres the wireless switch on an acer espire m1201 pc?
Hi
Desktop PCs do not generally have wireless switches. These are usually only to be found on laptops, netbooks and some nettops.
It is unusual for mid-specification desktop PCs like yours to have a built-in wireless function.
So the answer is that there is no wireless switch.
You can make a desktop PC wireless enabled by adding either an internal PCI wireless card or plugging in an external USB Wireless Adapter (far simpler). With these devices and their drivers and software installed, you will see a wireless icon bottom right of screen. Right click on this icon > View Available Networks/Connect to a Network to find your router's signal > once you connect to your wireless router by entering the SSID (router name) and Network Key (encrypted access code), the PC will be able access the internet wirelessly.
Once it is wireless enabled. whenever you turn the PC on, you just wait for the wireless icon to indicate you are connected to the internet (usually a blue globe).
There will never be a need for a wireless switch.
I hope this helps.
Aug 27, 2011 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Dlink dfe690txd ethernet card an my laptop i need instuctions on using it to get on the internet
Ok, install the drivers from the CD that came with the card, if you do not have these download them from D-link. After you have installed them, you then use that Ethernet adapter to connect to a Router/Modem, the Router, or Modem then connects to the Internet. Your Laptop connects to the Router/Modem, and then you can access the Internet.
Mar 03, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
How do i turn on my wireless capability?
Are you trying to turn on wireless in a laptop, PC or the modem itself?
Modems have a specific IP address that you can get from tech support of your internet vendor.
Laptops if WIFI onboard should simply have it.
Laptops with WIFI cards need drivers and sometimes software.
PC's with WIFI card or USB WIFI often need software etc.
Once working you then need a WPA or WPE login and password to access the internet. If at home you should have that information or call your ISP.
Oct 19, 2009 | Acer Aspire 5050-3242 Notebook
My laptop wont connect to the wireless internet
If your wireless can connect to your network but you can't access the internet than there is an easy fix that usually works. In most cases this is a configuration problem and not easy to track down. So, to bypass all the headache we are going to uninstall the adapter and let windows re-install it with fresh drivers. This will work better if you have the laptop connected to the internet via a ethernet cable but it's not required.
Go to control panel > System > Hardware > Device Manager > scroll down to network adapters > click on the plus sign and right click on the wireless adapter and select uninstall. Make sure the box marked remove drivers is UNCHECKED. We need to make sure the drivers are not deleted. Now, reboot the computer and let windows find the hardware...it will start the re-install and may even ask if it can search windows update to check for a fresh driver...click ok and let windows do its thing. reboot and when booted, try to connect to the internet.
Sep 15, 2009 | Computers & Internet
Internet wireless card
It's possible that the wireless driver is not installed or the wireless card is turned off in the bios or defective.
1. Check if the the driver is installed. Go to start. Right click 'My computer'. Left click properties. click hardware. click device manager. If there is a red 'X' on the wireless driver. Right click it and click enable. If there is a question mark on network controller or wireless driver. Click this link and choose the model of your laptop to get the wireless driver. Run the file to install the driver. Restart the computer if instructed then see if it worked.
2. If the light still wont turn on, go to the bios. You can do this by turning the computer off. Turn it on and repeatedly tap F2 right after pressing the power button. You should get a screen where you can change the settings. Click this link and choose your laptop's model and look for the instructions on how to turn on the wireless card in the bios. You may also browse the BIOS screen for that setting. Once you've set it to on, save the changes and restart the computer.
May 04, 2009 | Sony VAIO Notebook
Linksys Wireless-G problem with Internet connection
Have you tryed unpluging both routers then pluging them back in?
This will refresh your Ip's
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Belkin N1 wireless card stopped working in either port. No lights nothing.
ok...the IBM is notorious for incompatibility with standard wireless specs. first place to check is wireless card site, for Belkin unit. Get the latest drivers.
then on to IBM site, and get the wireless configuration utility.
Then cross your fingers that IBM, in it's infinite Big Blue wisdom, has not excluded your Belkin from it's list of compatible products.
I'm not surprised it works with other laptops, since most of them sign up for the compatibility IEEE standards.
got backup?
Feb 16, 2008 | IBM ThinkPad T30 2366 Notebook
Wireless connection
There are a few requirements other than the laptop and the wireless card. You need to also have an Wireless AP/Router that must be connected to the modem that connects to your ISP. All your PCs must then connect to this router either using the wired/Ethernet ports or WiFi.
If such a device (WiFi AP/Router) already exists and is connected to your modem and your other PC(s) are tied up to it and can access the Internet, you need to install the drivers (in a CD that came with the wireless card) to your IBM ThinkPad. Thereafter, you need to configure your laptop's wireless networking to access the AP/router. Your AP/Router must also be configured to accept wireless clients.
Please post back with brand/model of your AP/Router.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | IBM ThinkPad T20 2647 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
