Same for both doors? If not, I'd check the switch(s) on the drivers door (may be more than one), or may be just one that has multiple contacts and the ones for the lights may be faulty.
It's some kind of short. my guess either the wiring in the boot between the door itself and the frame/ body. or possibly in the circuit for the door courtesy switch, lastly the dome light circuit. if you have a test light, probe for a faulty circuit (grounding or incomplete)
A switch by the side of the indoor light normally is divided into several gear to feel it when the gear drive DOOR interior lights will be lit up want know more
If only the door ajar light and interior light is not working it is probably the door ajar switch located on the door latch inside the door. sometimes a little WD40 sprayed towards lower side of the latch will work, frees the piston in the switch. if not the switch must be replaced. If also the outside mirror control does not work, the door lock switch also does not work, it is a bad ground to those three systems, the Electric windows have a separate ground wire and still work. You must feed a new black wire from a good ground on the body thru the door accordion tube and connect it to the larger black wire on the plug that goes to the door lock switch. The door lock, the mirror control, the door ajar light, and the interior light problem will be gone.
hi ya it seems one of the door switches is broken or disengaged on each door frame you will find a push in switch witch operates the interior light, door warning light on dash and remote locking if one of them is not working it will show on dash as a door not closed it will prevent the interior light from working and also stop the auto locking system from working properly the locking system is connected to the interior lights
Hope yhis helps
Most likely the button on the door jam for the closed door maybe bad. Make sure the selection switch by the light is on DOOR. Then if the button is working, the open door symbol on your dash display should light up with the door open.
If it doesn't light up on the dash display with the door open, then the button on the door jam is bad.
Since it is only happening on the drivers side door to multiple switches and lights on that door only, I think the problem is the wiring harness as it enters the drivers door by the door hinges.
