Question about Toro Garden
I want to replace the impeller blades on my toro snow commander model #38600 serial #260000334 it has 3 blades. what is the right way to replace them
I have started to remove the blades but it is hard to get to the nuts and bolts.
    Champion:
    New Friend:
  • 215 Answers
Bolts rotate counterclockwise to tighten so go clockwise to remove.
Posted on Dec 14, 2014
panilling9
  • 284 Answers
SOURCE: The blade bolt is frozen on my Toro push mower and won't turn.
looking at the bolt you need to turn it counter clockwise
Posted on May 31, 2009
  • 8 Answers
SOURCE: bolt comes loose and rip cord is yanked from hand
  1. block off the blade and driver assembly with a 2x4 to keep it from moving
  2. remove the flywheel nut (regular hand force should be sufficient)
  3. tap the 3 holes on the flywheel (if they aren't already threaded) using 1/4inch 20national tap set
  4. remove the flywheel using a flywheel puller -- a harmonic balancer puller which matches the tecumseh bolt pattern on the flywheel also works using 3 1/4inch thread (20national, 2inch long) bolts with washers
  5. NOTE: (if the blade was removed/reinstalled, tighten the blade to manufacturer's spec of 60lbs) before installing the new flywheel key
  6. remove the sheared flywheel key
  7. clean up the flywheel (wipe off all the dirt and grease)
  8. install the new flywheel key (part 611004 for toro 20016)
  9. install the flywheel (pull the bail brake handle to get the ball-brake inside the flywheel)
  10. tighten the flywheel nut to manufacturer's spec of 37.5lbs
  11. prime the gas bulb, give it a pull and mow away
Posted on Aug 31, 2009
Testimonial: "excellent solution. easy to follow and precise!"
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Posted on Nov 13, 2009
  • 21 Answers
SOURCE: replace toro lawn bower blade
the bolts are torqued at the factory to a very high degree. you need a socket wrench with a long piece of 1 inch cast iron at the inserted at the end of the handle this will give you the leverage needed to loosen (and then re-tighten ) the bolt after you replace the blade
Posted on Dec 03, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Toro lawnmower appears flooded and won't start.
Actually all you have to do is take out the spark plug and pull the engine through several times. What has happened is the intake valve was open when you tipped the motor so when the fuel ran out of the carb into the engine it saturated the spark plug. You may have to by another spark plug to get it started or dry yours out very well. The main thing is to make sure that most of the liquid gas has exited the cylinder.
One more thing.... the float needle may have tilted a bit in the seat as a result of haging it tipped on its side. This is going to sound a bit strange BUT... grasp the handle and alternately bang the front and rear wheels on the ground a couple of times by lifting the back of the mower with the handle about 2 inches and drop it. Do the same by pressing down on the handle for the front tires. (2 inches and drop)
IT WORKS!
This should get you going. IF not just respond here and we can continue troubleshooting.
Kelly
Posted on Apr 15, 2010
Testimonial: "Thanks for the advice! I followed the suggestion and it worked like a charm. My hats off to you! "
Have a toro 2450 5 hp snowblower used to throw snow at least 8ft now lucky to go 1ft changed belt last year thought that was problem but didn't fix the problem any suggestions? Thank you
Just a thought. Is the belt tight or does it slip when you put pressure on it. Check and see if the impeller outfit is plugged. Mine did that and it was plugged with an old shirt I picked up in the snow. Can you turn the impeller by hand when the engine is shut down. If so could be a shear pin broke off in the impeller.
Dec 30, 2017 | Toro Garden
I would like to change the spark plog on my toro snowblower model 38600 s/n 240000387 but don't know where it is located. Thanks
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 15, 2017 | Toro Garden
Can the plastic impeller on a model 51591 be replaced with a metal #100-9076
Probably but the problem will be when vacuuming
plastic impellers absorb shock from stones and other hard objects, where as metal blades will break off causing an imbalance of the impeller
Apr 13, 2015 | Toro Garden
Replace impeller on poulan pro snow thrower
Is this a single stage where you may be calling the paddles an impeller or is it a two stage model? Can you please post the model and serial. I can get you more info and maybe a video.
Best,
Joe
Jan 18, 2015 | Garden
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here - http://www.partstree.com/parts/?lc=toro_consumer&mn=38182%2C+Powerlite+Snowthrower%2C+2009+%28SN+290000001-290999999%29&dn=3358-429-383366-0008
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - http://www.partstree.com/parts/?lc=Toro+Consumer&mn=38182 and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
I'm not asking about a leaf blower It's a toro snowthrower model # 38600. what's the proper way to remove and replace the impeller blades?
You have to disassemble the entire front of the snow blower. This means removing the snow shroud, auger bits and then getting to the impeller blades. I did it once and it took me about 1 1/2 hrs to complete.
Dec 14, 2014 | Toro Garden
How do I replace the blades on a toro 38600 snow blower
You should have a manual with instructions on replacements and alterations. Call Toro
Dec 05, 2014 | Toro Garden
My blower is running extra high and hard. so high that it shakes the cap off. how can i tame it down. model 51587
Remove the bottom of the blower or vac and see if any blades are broken on the plastic fan blade, known as an impeller. If a blade is sheared off, this could be the source of your noise and shaking. This part will need to be replaced. I've just ordered one and will be replacing mine when it comes in.
Jan 06, 2011 | Toro "Toro" Super Blower/Vac
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
95 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
