I need a manual for an Optique 32HD1E. Tv - Televison & Video
Where can i find a remote control for an Optique flat screen tv model #32HD1E?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 20, 2015 | Televison & Video
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
SHARP AR 5020 error F5-02
you reset your eror code program c#0#
May 30, 2009 | Sharp AR-5320 Black and White Copier
Electronic
1/ bine assurez que le DVD que tu as en train de visualizer est compatible avec le code regional de ton pays
2/ et aussice c peut etre le problem de la system optique de ton unite/ le lecteur /.
merci plz voter
Oct 16, 2008 | LG DR275 Recorder
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
