My heating element is stamped 1275w. Is it okay to use a 1350w element?
Everything else seems to be working, i.e. the fan blows, the flames glow but I doesn't put out any heat.
    Sergeant:
    Champion:
  • 282 Answers
If the flames glow then it seems that the heating element should be working. Can you supply any more information? And by the way you should never exceed any of the original heaters specifications because you may be creating a fire hazard even though it is only a small difference of 50 watts.
Posted on Dec 07, 2014
The oven heating element seems to be working but the fan is not working. It appears that the oven is reaching temp very quick and there is a red glow coming from the back of the oven which is where I...
If you can see the element heating up, but the fan is not working, then you need to replace the fan motor assy, if you do not, then the element is in danger of burning out.
Jun 23, 2011 | Ovens
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs....no heat
Make sure the lint filter and the exhaust vent pipe are not clogged.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 21, 2009 | Refrigerators
My dryer wont heat up
Nov 25, 2009 | Dryers
I have maytag dryer and it is blowing cold air. Everything else is working.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Nov 24, 2009 | Office Equipment & Supplies
Dryer not drying clothes
If the load is extremely large or heavy it may require more time. If you have an auto sensor cycle try that. If you are using the auto cycle and the clothes are not drying then the sensor may be not operating correctly. Make sure the lint filter is clean and that the exhaust vent duct is not clogged. Check all the way to the outlet. If all is clear then the thermostat2.gif may need to be replaced if it is not calling for heat as often as it should. Also check to make sure there is air flow from the vent. If not then the fan/blower may be broken or disconnected from the motor shaft.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Oct 21, 2009 | Whirlpool Dryers
I have the same Ruud Achiever unit & it's not working.
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Everything seems to be working fine but there is no heat
Sep 08, 2009 | Dryers
Heating element for oven
You just need a new element fitting. If it is fan assisted, make sure the fan is working o/k, if it is slow starting or sluggish or noisy,it is advisable to replace it also.
Plz rate this solution.
Thanks.
Dec 18, 2008 | Frigidaire Ovens
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
