Question about Vacuums
My tablets volume won't work after splash of water Please Help me to fix it!!
Dried quickly only outer case wet
  • 5,530 Answers
Turn off immediately! Dry thoroughly! Put in airing cupboard or near radiator ( not on it ) for a few hours! Then try powering up again!
Posted on Dec 07, 2014
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuum won't turn on
Be sure to that the latches are connected to the water pan. The eSERIES and up will not turn on without the water pan latched. If that is not the issue, please call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 17, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow E Series Vacuum won't turn on at all after it just worked fine
Allowing to sit on water pan for only 3 hours is not going to kill your Rainbow by itself. If there is no more information to this issue than what you described, the problem could be the motor is going bad and the thermal cut off is tripped. Possible reason it didn't do it while you were running the unit, is the motor cooling fan kept the temperature inside the motor just below the tripping point and then when you turned the machine off, this allowed the temperature to creep up past the limit and trip the thermal cut off.
RainVac
www.rainvac.com
800-523-0510
Oct 01, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
Rainbow vacuum won't power on.
Do you have it on the water pan? All models above the eSERIES will not run without the water pan.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I can get the acorn nut off the separator but cannot get the separator off the vacuum. Can I pryn it off, or will I break it?
It's probably stuck in place by dried-on fine dirt...if the nut has been removed,don't pry it, as it's made from light material to enable the high RPMs. Lightly spray soapy water around the edge, WHILE HOLDING IT WITH THE SEPARATOR DOWN so that the water won't run into the motor. Once the dried dirt's wet, it should be removable with a gentle twist or tap. Then clean the separator with a brush and soapy water and wipe down the bowl and canister, and dry it all with a soft cloth.
Aug 08, 2011 | Rainbow E series Canister Wet/Dry Vacuum
WON,T SPRAY CLEANER/WATER CARPET IS DRY.THE TOOL ATTACHMENT WORKS OKAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat 12 amp turbo carpet cleaner, not sucking water, model#8910
heatman101
Apr 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
teydh
Nov 30, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Open Questions:
Vacuums Logo
77 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
