When I turn on tv, the logo appears and then goes out after a few seconds?
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Posted on Dec 07, 2014
Testimonial: "Thank you very much, I did not know about this website. greetings!"
freetek
  • 5568 Answers
SOURCE: emerson tv goes off after a few seconds
The shutdown is probably caused by the power supply, although it may not be at fault, just trying to prevent a fire.
There may be other circuitry that is failing and drawing excessive current and most supplies are designed to turn off if the current drawn exceeds a certain maximum.
This is not a problem you can solve without technical skills.
Posted on Jul 07, 2008
josetejas
  • 300 Answers
SOURCE: JVC LT-42E488. No picture. JVC logo comes up for a few seconds.
A firmware update might fix it. Call an authorized servicer, explain the symptom.
Posted on Jan 29, 2010
techman007
  • 1112 Answers
SOURCE: Tv will turn on vizio
Hi:
This is due to problems related to the power supply, have the PS checked for leaky capacitors, also you need to make sure its not just the back lights turning off, ususally when tv's today shut off they give and error code on the standby light, blinking and the number of times it blinks gives a indication of the problem area.
Posted on Jan 28, 2011
Zephyr0u812
  • 27 Answers
SOURCE: When I turn the TV on the Westinghouse logo
One of the inverter transformers could be blown too. You can buy them on e-bay by entering the number from the top of the transformer, It requires soldering. The bad transformer will be 'leaking' or will have burned the circuit board.
The problem I have had is that even after replacing the transformer, the over-current circuit kicks in and the same 'shut-off' thing happens. I replaced all of the blue 5pf 3kv capacitors with 5pf 6kv caps, and still the same problem.
finally, I just removed all of the blue capacitors by the transformers and now it works great!
Unfortunately, this bypasses the over-current protection and the set will not turn off next time a transformer has a melt down. Possible fire hazard.
be careful with this fix.
I would recommend not leaving the set unattended, and if you smell burning, turn it off.
Unfortunately, since the manufacturer was nice enough to shellac or leave a heavy rosin coating on the solder side of the board, it is really hard to test individual components :(
Good Luck!
Posted on Mar 08, 2012
SOURCE: tv screen goes black ater 10 seconds
there could be several things causing this, most often it's a defective inverter, or a bad CCFL lamp. You could also have a problem with 24vdc output from the power supply, or "backlight on circuit from the main board. Get a proper diagnoses.
Posted on Sep 09, 2012
When I turn on tv, the logo appears and then goes out after a few seconds. tnx
Sounds like corrupted firmware. Update the firmware with latest version. Contact the authorized service center. Electro help
Dec 07, 2014 | Televison & Video
Tv screen goes black ater 10 seconds
Sep 08, 2012 | Westinghouse TX-47F430S 47 in. LCD TV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
Jan 27, 2012 | Samsung 32 UN32D4000 LCD TV
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
Polaroid LCD on Digital Picture frame goes black during power-on
likely the old one had a bad inverter or a back light problem.
Jul 12, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
