Question about Furniture
How do I fit light replace light bulb - Furniture
  • 35 Answers
Phone the retailer or phone the branded manufacturer site, they may be able to sort you out with the right bulb and a good idea of how to replace it.
Posted on Dec 07, 2014
Testimonial: "Thanks."
  • nobywilliams Dec 07, 2014
    you're welcome, have a very bright Xmas lol
What is the unscrewing tool for the lights
On the backside of the light lens is where the light bulb is changed. There is usually a white fitting that houses the lamp in a socket fitting.
Get to the backside of light fitting and you can change the bulb.
Rod
US Parts Center
Nov 27, 2013 | Maax Living 6636 Hydromax Whirlpool -...
Cant find a light bulb to fit my Monte Carlo model #227880
You can buy a replacement bulbs at Home Depot its a Phillips T4 mini candelabra 75 watt halogen bulbs It's a small cylinder shaped bulbs
Feb 26, 2013 | Monte Carlo Dryers
Front passenger head light fails even with new bulb on 1995 nissan sentra
This is likely caused by using the wrong bulb.
You can certainly purchase after market bulbs of more modern technology that provide much better illumination than the manufacturer recommended brand. HOWEVER, those bulbs having a matching part number to what is recommended does NOT mean it is what you should necessarily use. The reason is the wattage. Higher wattage produces more heat.
Try a bulb of a lower wattage rating. I recommend going no higher than 20 watts beyond your original rating, do not allow the bulb glass to get dirty while installing nor touch with your bare fingers, and inspect your ground connections to the headlight assembly for any breakage, corrosion or looseness. Good luck!
May 04, 2012 | Nissan Sentra Cars & Trucks
Replaced passat side marker light. Now it does not fit tight.
Is it the bulb that does not fit tight...or the socket is loose in the bezel? You can carefully (with needle nose pliers and/or small screwdriver) bend the inside tabs of the socket for a tighter fit...also be sure you are using bulb lubricant to properly seal the bulb in the socket...Both fits are imperitive to new bulb life, and moisture proofing your marker light. Be sure you have not mis-placed a rubber seal that goes around the socket to assure the marker light stays dry. You can make a replacement gasket for the seal by using a thin piece of rubber...ie (bicyle innertube) trace around socket for new o-ring seal, and cut out with scissors. Hope this helps.
Apr 02, 2012 | 2003 Volkswagen Passat
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    How do I change a brake light bulb in a 1999 c70 volvo?
    Welcome to FixYa.com
    Brake Lamp Replacement
    Location of the lights
    The illustration shows the locations of the lights on the RH side. The LH side is the same but
    mirror-reversed.
    The lights have the following functions:
    - 1 +1 = Parking light Fail light
    - 2 = Reversing light
    - 3 = Fog light LH side only (LHD cars)
    - 5 = Direction indicator
    - 6 = Brake light
    Tail light changing bulbs
    Ignition off.
    Open the cover in front of the tail light
    Undo the wing nut and take out the lamp holder.
    Change the defective bulb.
    Fit in reverse order.
    Check that all bulbs lamps are intact and in working order.
    Replacement of tail light cluster
    Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
    Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
    connector for the tail light Undo the four nuts securing the tail light see illustration.
    Pull the tail light straight out. Fit in reverse order
    Note! check the sealing and fit on reassembly.
    Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
    Jan 27, 2011 | 1999 Volvo C70
    Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
    It' a unique bulb that is available online. The big box stores don't carry it.
    Oct 23, 2009 | Panasonic FV-11VQ2 Fan
    Replacement bulb for Panasonic FV-11VQL4 does not fit
    YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
    Mar 12, 2017 | Panasonic Kitchen Appliances - Others
    Brake light wiring reversed?
    hi go back to bulb and make sure the bulb you have fitted is for indicator? this has only one element and has only one centre contact for power also check the side pins on the body of bulb they should be opposite one another and on same level as you look on side however here in uk some of these bulbs are the same as above but for the locating pins as described above the pins are on same level but not opposite each other so if you try fitting should not be able to fit easily bayonet suggest you check the other side rear light bulbs one at atime to ensure correct type are what you have fitted stop and tail light bulbs have two elements one for brake and one for tail light these locating pins are oposite each other but not on same level offset to ensure the elements are on correct circuit when fitted hope you understand ?
    Nov 02, 2008 | 1995 Ford Contour
    Tail light blinker replacement
    Laura E;
    Most tail light housings use the same approach. The bulb is removed from the housing by twisting
    the back of the bulf where the wires are. Usually the bulb itself has a rubber back and turning it about a quarter turn counterclockwise (remember lefty=loosey; righty = tighty) will release the bulb it from the taillight housing. Take the bulb with you when you go for a replacement to be sure you get the right one.
    The bulb will only fit one way into its socket and the socket will only fit one way into the housing.
    Good luck ,
    Loringh
    Oct 14, 2008 | 1994 Ford Thunderbird
    Furniture Logo
    82 people viewed this question
    Top Furniture Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Furniture Expert? Answer questions, earn points and help others
