Question about Bissell 22K7e Cleanview Lift Off Carpet Cleaner
Brushes not rolling
Tried getting red of pet hairs and debris trapped in the brushes but it still is not rolling.
    Top Expert:
  • Bissell Master
  • 41,701 Answers
You may have to remove the brush roller and disassemble it to remove hair and debris trapped inside the end caps.
Posted on Dec 07, 2014
Change a belt
You did not state your model or make so I can't explain how to change your model but most vacuums you must remove the bottom plate held on by screws that covers the brush roll, remove the brush roll and belt and reverse the process with the new belt. Some models have the brush roll held in by screws and/or brackets, some brush rolls slide down into slots. Replace the brush roll if the bristles are worn or frayed. If you are not replacing the brush roll remove the endcaps if possible and clear any hair or debris that has worked it's way in there.
Cogged belts are different from stretch belts and do not need to be replaced at least once per year like stretch belts do. You should still remove the brush roll at least once or twice per year to clean out debris. Maybe more often if it gets hair or strings wrapped around it which can build up causing friction and heat which can melt or damage the brush roll or even the nozzle housing.
Jan 29, 2017 | Vacuums
Bissell proheat pet brush is spinning but loud noise and vibration at same time
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has not work properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 23, 2016 | Bissell Vacuums
How do I make the brush rotate on my Bissell preheat pet carpet cleaner
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
Ava B.
Feb 21, 2016 | Bissell Vacuums
Shark navigator uv440 pet brush won't roll
The hair in the bearings. I take pair of needel nose peirs. Its hard,but it only i found
Jul 14, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Change Belt
Hair and debris works it's way under the end caps of the brush roll causing a restriction. If you can't clean the debris out and get the brush roll spinning greenly you may need to replace the brush roll.
Mar 25, 2014 | Vacuums
Groaning noise when it suctions
Check for hair and debris in the brush roll
Jan 08, 2014 | Dyson DC25 Animal Upright Ball Bagless...
I have a lift-off bissell vaccuum and as I vacuum often the power brush will turn off and on. How can I fix this?
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Jul 16, 2011 | Bissell 37604 Lift-Off Pet Bagless Upright...
My brush will not turn on my Bissell 6393 upright bagless vacuum... what is wrong? The belt broke and I replaced it twice... I now have 6 more replacements but the brush still won't rotate. Do I have to...
This type of plastic brush roll fails pretty frequently. Hair and other debis gets jammed in the end caps. The hair and debris gets hot which in turn tends to melt the plastic end caps. Remove your brush roll, hold the ends with your fingers and try to spin the brush roll. If it does not spin freely then it is probably damaged or clogged up. If it's not damaged beyond repair you may be able to unscrew the end caps and clean the debris out. If you can't unscrew the end caps then they may already be meted shut. Bissell part number for your brush roll is B2032305.
May 17, 2010 | Vacuums
Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Dec 30, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell 22K7e Cleanview Lift Off Carpet Cleaner Logo
336 people viewed this question
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
