Question about Yaesu FT-2700 Technical Manual
Yaesu 270 not transmitting nor receiving
Reseted settings to factory defaults
    Sergeant:
    Champion:
  • 282 Answers
Your question is very vague. In order to answer I need to have more information. Does it light up? Have you checked the fuse? Have you checked the power supply and the power cord. If you are using a mobile cigarette lighter socket and plug have you checked them? If you have done all of these things and it still doesn't work but it does light up then you can try a reset. Hopefully you will be able to find the problem with what I have suggested.
If not then here is the owners manual.
http://www.radiomanual.info/schemi/FT2700RH_user_D.pdf
One ham helping another ham. Good luck, Marty WA2YYX
Posted on Dec 07, 2014
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
Is there a secret button combination to hard reset Yaesu FT270?
So you used the power on MONI depress/ channel F4 method to reset the unit and it did not work?
Dec 12, 2015 | Yaesu Ft-270r 5 Watt Waterproof Vhf Two...
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
May 16, 2015 | Yaesu FT-990 DC Transceiver
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
May 16, 2015 | Yaesu Radio Communications
Hi this can be down to many reasons, radio keypad locked, receive on tone squelch, set on "Relay" or "Repeater", or even radio failure. Without the radio I cannot help, but that may give you some ideas.
Feb 14, 2015 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
Yamaha RX-V359 the remote sensor in in the unit is not working. I have tried the remote control on another machine and that works
If the remote is working, but not with your receiver, there is maybe ID mismatch. Both the remote and receiver can be set to either ID1 or ID2 - this is used when you have 2 receivers nearby, so that both of them don't react on commands from both remotes.
See the "Advanced setup" of your manual. On receiver you can check/change the ID code by powering the receiver on (press STANDBY/ON) while holding down the STRAIGHT button on front panel. Display will show "Advanced setup". Use "program < >" keys to navigate the menu until you got to "REMOTE ID-XYZ". Then press STRAIGHT to select ID1 or ID2. Now press STANDBY/ON to turn the receiver off. After turning it on again, it will use the new settings.
You can also try to reset the remote control codes to factory defaults. On remote, press CODE SET with a tip of a pen or pencil. TRANSMIT light on remote will blink twice. Now press SETUP on the remote and then "9981". TRANSMIT should now blink twice and remote control is set to factory default codes.
Oct 12, 2014 | Yamaha Audio Players & Recorders
MY YAESU 411E GOT OUT OF BAND WHAT SHALL I DO ?
Go online (possibly www.mods.dk) and get a user manual, Do a "factory reset"...
Sep 18, 2012 | Yaesu Radio Communications
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Yaesu FT-2700 Technical Manual Logo
85 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
