Question about Home
My triton shower unit is leaking at the bottom,do you think its the washer,if so how do i change this.
I HAVE TAKEN THE CAP OFF FROM THE UNIT AND THERE IS A BRASS VALVE THERE ,DO I REMOVE THIS TO CHANGE THE WASHER.
  • 659 Answers
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Posted on Apr 03, 2009
  • 297 Answers
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Posted on Jul 16, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
  • 12650 Answers
SOURCE: i have a new single handle shower valve and when i
single shower units are shipped in cold position as a safety u have to adjust ur anti-scold clips to allow hot water --- that red clip is ur hot adjustment-- if u have ur paperwork for the unit in it explains on how to adjust[ but]=== if u pull back the red clip [it sits on a spline of teeth] and turn it put back on so the valve opens do it in small increments till ur comfortable with hot adjustment will take a few times
Posted on Mar 02, 2010
SOURCE: My Triton (Jade) electric shower has abruptly
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Posted on May 06, 2011
Water is coming out of the bottom of unit shower triton t100xr
Sounds like the valve is leaking. TURN THE POWER OFF and isolate the shower from the mains. Call a plumber if you are not competent to repair the valve.
Jul 28, 2017 | Home
TRITON SHOWER WATER LEAKING DOWN WALL AT THE BACK
Sorry to say most parts are plastic and sometimes deform,the cost to repair could be more than a new unit.very easy to swap,bite the bullit
and replace
Jul 01, 2014 | Grohe 25 597 Talia Tub Filler w/Personal...
Triton delta 7 shower leaking from back of unit
that leak will damage the walls and ceiling below. If you cannot find the leak visually, call a plumber before much damage is done.
Jul 30, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
How do I open a Triton shower box ?
there are usually screws on the top and the bottom of the shower unit holding the front cover on.
Apr 11, 2010 | Home
My shower works. water also poors out of a tube beneath the unit
Apr 02, 2009 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
