I need to boot Win7 by USB flash Drive created by a 2.5"FF SATA drive.
I installed Win7 on a 2.5" form factor SATA hard disk drive. Later I converted this drive to USB Flash Disk Drive by installing in covertor box available in market. My computer is detecting on USB all the NTFS partitions I made during Win7 installation but win7 is unbootable through USB, why? How I can acheive this?
    Top Expert:
  • Computers & ... Master
  • 22,688 Answers
If you can tell your BIOS to use USB as the first boot device and the USB is from an ISO of Win7, it should work but your laptop won't be happy as the drivers may be wrong.
Posted on Dec 07, 2014
Testimonial: "I tried this but was unsuccessful, I am using Dell Optiplex GX280 small form factor desktop computer not a laptop. When I selected only USB bootable through CMOS setup, it didn't work and computer is not detecting any USB boot device."
I have western digital external hdd usb 2.0 and i have opened it now i want to connect it as internal hdd, its a sata drive inside when i opened the cover
The specific connection depends on the form factor the hard drive mechanism and the computer in which you want to install it. If it's a 3.5" drive and you want to put it in a laptop, forget it; it won't fit in there.
If you want to put a 3.5" drive in a desktop system, you need a SATA drive power connector from the power supply, a SATA data cable, and a SATA port on the motherboard or an expansion card. (note that you will probably not be able to boot from this drive if it is connected through an expansion card unless your computer's BIOS supports booting from a PCI device). It's also highly desirable to have an empty drive bay in which to to mount the unit.
If the hard drive has a 2.5" form factor (2.5" wide), and it is to go into a laptop, you will need the 2.5" hard drive adapter for your particular laptop (many manufacturers have a special cable or adapter for hard drives, although they should all fit the SATA interface. However, if your laptop is an older model designed for PATA IDE drives, the STAT drive will not be compatible.
To put a 2.5" SATA drive in a desktop computer, you need an adapter kit. This includes a 2.5" - 3.5" drive mounting bracket adapter and a cable adapter connector for 3.5" drive connections as described in the second paragraph above. Many computer parts merchants carry these.
Sep 21, 2014 | Computers & Internet
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
Dec 30, 2008 | Kingston Technologies 512MB DataTraveler I...
Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option...
Hi.
I will explain you the issue.
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
http://www.scribd.com/doc/4864999/sata
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Sep 09, 2008 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
