Can't get the TV to pick up Chanel's or play devices. Zsylvania DTW2405
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Check and replace its tuner. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 07, 2014
When I try to play a cassette the cassette clicks on and turns normally. However, all it transmits to the TV is wavy lines and no picture of sound. The TV does not show the play, stop,etc. indictators when...
The TV channel should be set on Chanel 3 or Chanel 4.
Use the remote control of the TV to set it.
You can also use the AUX ports (to TV) on the VCR and connect the three wires to the AUX ports on the TV (TV input). The two audio wires are to be connected to Audio in and the Video signal to the Video input.
If you get a garbled picture you can use press the tracking button on the VCR. Usually you press the Channel Up arrow, or Channel Down arrow to adjust the picture.
Dec 22, 2013 | Goldstar Televison & Video
I connected my dvd player to my coby hd tv, and the movie still want play, maybe I have it on the wrong chanel. What chanel should the hd tv be on?
Are you using a HDMI cable? Push the SOURCE button & select the corresponding HDMI input with the HDMI input from your DVD player. The HDMI inputs on the tv should be numbered & you can then select the correct number HDMI on the source screen. Good luck.
Sep 02, 2013 | CobyElectronics Coby Electronics Coby...
Orion tv model 1933 only 34 and aux
change your memory ic ( 8 pin ic ) or" reprogram your memory ic.channel store problem solve 100%.
May 29, 2012 | Orion1934 19" TV
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Get nothing but static when i turn it on
make sure you go from the cable box were it says out to the in on the vcr from the vcr you want to come out to the tvnow you can program the the vcr to pick up the cable chanell from the boxthe vcr has to be on chaell 3-4 in the front were it shows what chanell your on then the tv and the vcr are to be on the wright cahells the tv has to line up with the chaell your useing for the vcr3-4 to make this less complicated put a tape in the vcr hit play if its playing you are on the right chanel you do not have to have the vcr to watch cable it will go threw even if vcr is off just have to be right chanel
May 18, 2010 | Sylvania 6260VF VCR
Just got a n64 off ebay power cable and an antenna cable came with it. no idea how to tune the tv so i can play it!!!!!! i have tried manually and automatically searching through all the components and...
It has been a long time since I have used one but I believe you can hook it directly to the rca jacks in the back of the tv... then I believe you need to be tuned into the AUX chanel on your tv set ... some tv's if you hit 00 this puts you to it ..others start from chanel two and go down ... hope it helps .. have fun playing the 64
Oct 16, 2009 | Nintendo 64 Console
Panasonic dvd rv32 tv set at ch 00, play,sound only - no pic
you idealy need to use a scart lead from the dvd to the tv, then pick the "av" chanel it is plugged intoon the tv. You get a much better picture using a scart lead.
May 09, 2009 | Panasonic DVD-RV32 DVD Player
DVD chanel problem
Start the DVD and press the "input" button on your remote until you see the dvd you are playing.
Mar 01, 2009 | Samsung DVD-VR357
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Televison & Video
Panasonic triple play tv
press tv/vcr first on the remote then use the chanel up or down to select the next input.
Feb 08, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
