Question about Bosch Washing Machines
Bosch Logixx 8 with a f27 error- what could cause this?
I had the digital card repaired, cleaned the machine, cleaned the pump.
  • Chaya Norkin
    Chaya Norkin Dec 09, 2014
    My washing machine will do a full cycle. When the timer on the display is down to the last one minute, it just stops. This means that the cycle never ends, so in order to get the laundry out I have to turn the knob to off and wait for the door to unlock. Sometimes the machinne will give me an F:27 error message and again, I have to manually turn off the machine and wait to open the door. The memory card has been repaired (or so we thought). The machine was run on empty and then cleaned with Bosch wasing machine cleaner. Cleaning the machine clogged the pump with soap residue. I cleaned the pump and now the machine is doing what I described which is what it was doing before we had it fixed. The f:27 is new since the machine was cleaned.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
The code means that the pump out pressure is to high
this can be caused by a partial blockage in the filter, the pump, the hose to the drain or by a drain hose that is to long or up to high above the washer
it can also be caused by excessive foam
Posted on Jul 26, 2015
SOURCE: Bosch washing machine logixx 8 front loader error
I forbindelse med start af vaskeprogram melder maskinenen F37 fejl? hvad betyder det?
Posted on Jan 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 6277 Answers
SOURCE: I han F 18 error
Bosch 'F18' indicates a filter problem.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
  • 6277 Answers
SOURCE: I have a Bosch Logixx
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Posted on Sep 15, 2011
Testimonial: "Thanks - the engineer is coming later today. "
SOURCE: How do you remove Pump Cover on Logixx 8 washing machine?
I have a solution.You just keep turning the white knob anticlockwise. Use a pair of pliars to aid the turning keep going clockwise and anticlockwise if it gets stuck. It will rotate. Just opened my one and found a lollipop stick and a collar stiffner. Good Luck.
Posted on Dec 02, 2011
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch washer sometimes don't rinse
Have you cleaned out the filter in the bottom and made sure the pump is not blocked?
Apr 22, 2014 | Bosch Washing Machines
F27 fault on bosch logixx 8
F27 is a problem with the pressure switch
Nov 04, 2012 | Washing Machines
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Feb 16, 2009 | Bosch Logixx WFT 2806 Front Load...
My Bosch washing machine (logixx 8) shows error code F37 and beeps
Jan 06, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
241 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
