Question about Preethi Blue Leaf Platinum 550 Watts 3 Jar Indian Mixer Grinder 110
Hi i have one new mixer preethi brand 750 watt its always making short from carbon
We bought arround 20 mixer grinder since 6 year .of this brand.but always problam only fire coming from near by carbon area.
Replacemnt of brushes 750 watts preethi mixer grinde
replacemtn for a brush can be a spatula sometimes. depends on the dinner
Sep 09, 2016 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
I don't have a problem I just wanted to know the difference between the two products. I have the KSM 90 and nothing is wrong with it. I just wanted to know how much of a difference between the two. ...
Except for asthetics and whatever obvious trim such as handles on bowls, etc, there is NO PRACTICAL DIFFERENCE; both mixers are outstanding appliances.
There has always been ONGOING MODIFICATIONS in motor design, relating mostly to formation of the electromagnetic flux and other intangibles, you will find OLDER KSM90s may have a slightly higher degree of OVERBUILDING- such as COPPER plating flashed on the back end of the carbon brushes to improve effciency, reduce heat, and lower electricl resistance, another example is oil wick felts included with the rear bearing assembly to help lubrication on older models. In both cases its over-engineering and it costs money- Ive never been able to read difference between the two carbon brushes on a Watt meter in actual use, nor have I ever actually seen, in more than 30 years mostly as authorized warranty service center more than just one single WORN rear bearing (from a mixer in a science lab, not a kitchen) with or without the oil wick felt- thats out of several hundred thousand mixers!
Newer mixers lack other similar accoutrements which had proven to provide limited tangible benifit on a practcal level.
KitchenAid keeps knowledgeable staff available at their 800 phone line at customer service to go into this subject without the unnecessary technical depth I've given,, and they may yet recall my name after these many years -DeSantis (Im the [disabled] son, JD2, not the grandson)- from the Trenton/central NJ area.
Sep 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Hi, Our Indian made Preethi Eco Chef mixer had stopped working after pressing the overload button repeatedly, any idea whether any repair centers in and around Ipswich
Hi, please replace the Overload button (Circuit Breaker) with a new one. You can purchase the Overload protector (Circuit breaker) in any nearby Mixer repair or Electrical shop. Please take the old Overload protector to get the new one of same specification which suits for your Mixer.
Apr 16, 2011 | Food Mixers
I need to know what size of carbon brushes do i need for my oster 6627 milk shake maker
CHECK THE MODEL NUMBER ON YOUR MACHINE OR GET THE MOTOR OUT AND LOOK FOR PLACE THAT REBUILD MOTOR ASK THEM TO REPLACED THE BRUSHES AND THE MOTOR CAM.WILL WORK LIKE BRAND NEW MOTOR ..
Feb 18, 2011 | Oster 100 Watts 6627 Stand Mixer
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Preethi Blue Leaf Platinum 550 Watts 3 Jar Indian Mixer Grinder 110 Logo
96 people viewed this question
Top Preethi Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Preethi Food Mixer Expert? Answer questions, earn points and help others
