Question about Dewalt Drills
I brought an 18v battery De9098 from Amazon it will not slot into my blinking charger It appears to have three connecting points my old battery only has two. Can you advise
MY DEWALT BLINKING BATTERY CHARGER HAS TWO CONTACT POINTS. THE NEW BATTERY OBTAINED FROM AMAZON WILL NOT SLOT INTO MY CHARGER. IT LOOKS LIKE IT HAS THREE CONTACT POINTS. WILL I NEED TO PURCHASS A NEW CHARGER? IF SO WHAT MODEL? OR WHERE CAN I GET A BATTERY TO FIT MY OLD CHARGER?
  • Dewalt Master
  • 1,902 Answers
IF your battery is having 3 contacts you are lucky but your charger must have also that 3 contacts because that thirth contact is a deep discharge-protection to warn you if the cells are become to low for DC voltage the switch in the machine -the battery and the loader must all off them 3 contacts to will that worked.
The motor stopped immediately if the voltage is becomming to low .the thirth contact is responsible for the protection.
Batteries are expensive wrong batteries more but there are ways for rebuild the switch and batterie contactplate as first. and after that the charger. it will give a longer freshment of capacity.
Posted on Apr 12, 2016
    Habit-Forming:
    New Friend:
  • 28 Answers
Brand New Cordless Drill Battery for DEWALT DE9098
  • Type: Ni-MH
  • Volt: 18V
  • Capacity: 3000mAh
  • Color: Black
  • Weight: 1160g
  • Dimension: 136.80x85.43x113.00mm
http://www.drill-battery.com.au/buybatteries.php/dewalt_DE9098_power+tool+battery.html
  • Type: Ni-MH
  • Volt: 18V
  • Capacity: 3000mAh
  • Color: Black
  • Weight: 1160g
Posted on May 20, 2015
  • 313 Answers
SOURCE: i HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Posted on Jun 21, 2008
emissionwiz
  • 79189 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Posted on Mar 20, 2009
  • 43131 Answers
SOURCE: can dewalt 18v batteries be repaired
Theoretically yes. Practically no.
Posted on Oct 11, 2012
  • 304 Answers
SOURCE: 4 contact points on charger yet only 3 0n rhe Battery. what do they do actually. I understand the + and -
They are to do with the feed back for the PCB in the charger and tell it when to switch it off and also sense the condition/temp of the battery.
Posted on Dec 17, 2012
Can I use a 12 volt dewalt cordless battery charger to charge my power on board sport spot 20 million power series floodlights?
There are many factors to be aware of. One of witch is, will the charger accept the male portion of the power sport. The contact points must align perfectly with one another. The power ratios must be exactly alike with the power charger and the sport spot. If not, you could have mismatch and blow the entire floodlight system. With DC applications, low level power usually is of little consequence unless the amperage is excessive and then you have s problem. You make the call.
Feb 04, 2018 | Dewalt Drills
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
DW 911 radio works on mains power but not with battery inserted
Change the battery connector pcb board part# 5140019-41 12.07 on ereplacementparts.com
Dec 06, 2014 | Radio Communications
Dewalt charger normal flashing with no battery connected
please clear the contact of the battery and charger, charge the battery again. If still no help, please use a good battery to see if it is the problem of the Dewalt DC920KA battery or the charger.
Jul 11, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DE0245 battery charger blink fast without battery inserted
It really sounds like the electronics in the charger are failing or failed, it's probably cheaper to buy a new charger
Mar 25, 2014 | Computers & Internet
I am in Canada and I cannot get a Black & Decker 36V charger which is LCS36. The B & D 36V battery looks identical to the Dewalt 36V battery but I cannot be positive. Do you know if the B & D LBXR36...
What I do know is that some NiCd 12V Black decker batteries that look similar to the dewalt ones they are charged by the dewalt charger.
But there are 12V Nicd black and decker batteries that they can not be charged due to an extra plastic edge that does not allow to be charged by the dewalt charger.
Now if you do have the dewalt lithium 36V charger and if the black and decker battery is a 36V lithium one and can not be charged due to a plastic edge then I would recommend to risk to destroy the plastic edge in order the black and decker battery to be charged.
Sep 25, 2013 | Dewalt Black & Decker / DC9360 36V Battery
I go to charge the battery and it looks like it charges for a while then the charger red light starts blinking. I put the battery back in the camera and the battery is still flat. Not sure what's wrong?...
The blinking light on the charger indicates that the battery needs to be replaced and will not charge. You can buy a replacement lithium battery online at sites like Amazon for less than $10.
Nov 18, 2010 | Olympus Stylus 820 Digital Camera
I purchased a new charger for my Dewalt Cordless drill and the red light just blinks. Is this normal
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
Apr 25, 2010 | Dewalt Drills
Have just got the Dewalt DE9116 charger.Plugged it in & red light comes on & then goes off.Is the charger working properly?Have no instructions
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
Sep 23, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
332 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
