Akura T V mode apld2yr32h1tfd hand control works on all bottoms except it will not turn tv on or off.Have to do it manually.
I have an akura apld2yr32h1tfd tv unfortunately i lost the remote bought a signalex 10 in 1 remote but the codes dont seem to work anybody with any other coded plz.
This is the code to check. 1232. It seems to be very difficult to get setup codes to this brand TV. anyway, check these links. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 11, 2013 | Televison & Video
I need tv code of "akura"
0938,0917,0933 are the codes to check with Akura brand TVs. If you wish to get more codes, http://electrohelponline.blogspot.com/ check this link. Pull up older posts there.
May 28, 2013 | Televison & Video
Akura TV, Model Number : AVL CD32700-S, Serial Number : 5974609 600288 I haven't got a manual ! Please help
I can't find anything with that model number. Perhaps you have a Akura AVLCD270-S 27" Widescreen LCD TV, in which case the manual is here.
Feb 12, 2012 | Televison & Video
My akura tv remote stopped working so i bought a universal remote but i cant get this to work either
Hi Peter, we would need more info....
Model # of the TV
Are the akura codes not available for the remote?
If available is it that none of them work?
Jun 09, 2011 | Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Good evening, I've been trying to set my one for all with my Akura LCD TV and I can see some functions are working. However not all of the bottoms are responding. I tried all of the suggested codes in the...
Hi Giomaravilha,
Universal remote control has a limitation in terms of button function most especially in some brands. This would not perform all of the button like what the original remote can do. The major button that will be working sometimes is the Channel and volume alone and not all the respective button. It is better to have an original remote, but the problem is that sometimes even the retailer of the unit can't produce or sell at all. You can try to find the original remote online. Try shopjimmy.com or ebay.com to find whether if there is an available remote control for your tv. Just type the brand and model no. of your unit to the search engine and click the search button.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 12, 2011 | Televison & Video
Akura tv dvd combo remote control codes
just got sky and need a code for the remote as i cant use the volume on it
Jul 27, 2008 | Televison & Video
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Nov 16, 2007 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
