Question about Konica Minolta Office Equipment & Supplies
How do i refil konica minolta pagepro 1500w
I tried to refil konica minolta pagepro 1500w cardrige but after refiling the print becomes dirty.What shall i do to get rid of it.
  • Konica Minolta Master
  • 6,161 Answers
Buy OEM CARTRIDGES. The cart ridge have sensor on the machine can tell used from new
Posted on Jan 03, 2015
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
herminio_hal
  • 210 Answers
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Posted on Jul 09, 2009
SOURCE: KONICA MINOLTA PagePro 1350W
You have to connect it to exactly the same USB port. For every time you connected to a different port compared with the last one, a new copy will be installed.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
freetek
  • 5568 Answers
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Posted on Oct 10, 2009
  • 35 Answers
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Posted on Feb 16, 2010
Konica minolta pagepro 1500w drum error
The Pagepro 1500 is an older design and the drums on those are only rated for around 12,000 pages or so. Unless you have a computer that can query the printer directly to get the error code the print driver is giving I can only recommend disconnecting power, remove toner, remove and replace drum, replace toner and reconnect power. (Cold reset) But, if the drum has reached its end-of-life then the only option is to replace the drum. At that point it's better just to buy a new printer; the drum replacement cost will probably be prohibitive.
Oct 26, 2016 | Konica Minolta Office Equipment & Supplies
Can't find a compatible driver of Konica Minolta pagepro 1500W for mac os 10.8.1
All available drivers for konica minolta machines are located at kmbs.konicaminolta.us .
Mar 06, 2014 | Konica Minolta Office Equipment & Supplies
Toner error
There are chips on the toner cartridge, that how the printer known it got a new cartridge so refilling does not work.
Jan 05, 2014 | Konica Minolta PagePro Office Equipment &...
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
Sep 15, 2013 | Konica Minolta PagePro Office Equipment &...
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
    Konica minolta 9J04 refill
    Unfortunately you have to replace the chip or to reset it after the toner refill. The chip keeps count of the number of pages that was printed with that toner, so there is no easy way out.
    Nov 20, 2008 | Konica Minolta PagePro 1350W Laser Printer
    191 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
