Question about Cell Phones
I reset my z.doxio mini sm-n900 now things dont work how do i fix the phone
How can I unroot my note 3 to Tmobile on windows 10 without usb.
How to Unroot Samsung Galaxy S3! [No Computer] [AT&T/T ...
www.androidrootz.com/.../10/how-to-unroot-samsung-galaxy-s3-no.htm...
[No Computer] [AT&T/T-Mobile/Verizon] ... What will unrooting my Samsung Galaxy S3 do to my phone? ... 3. Tap on "Reset flash counter". 4. Next, download and install Odin Mobile app ... and choose "extract", this process will take about 10 minutes to extract the zip file. .... USB driver is installed but still cant get it to work.
How to unroot Samsung Galaxy Note 3 [Guide] ' Reviews ...
dottech.org/135324/how-to-unroot-samsung-galaxy-note-3/
Nov 18, 2013 - Step-by-step guide on how to unroot your Samsung Galaxy Note 3. ...SM-N9005; SM-N900 Octa-core; SM-N900T T-Mobile; SM-N900V Verizon; SM-N900P... I tried the differenct USB ports on my laptop, but no luck. ... [Guide] · How to add Google Calendar to Windows 10 Calendar app [Tip] · How to root ...
How to Unroot Galaxy Note 3! ' GalaxyNote3Root.com
Jan 01, 2016 | Generic Note SM N900V SM N900A SM N900T SM...
Reset lock code for my n900 can you help please
Default code is 12345
if this does not work then sombody might have changed it
now it can be doone by using software equipments like UFS-T or ATF box as under or get it done from a service guy
41207da2-01e6-4ab8-9c88-4fa41552bfa2.jpg 92708f1e-de5a-46a1-b073-dacf278a49ce.jpg
Jan 11, 2014 | Nokia N900 Otter Box
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
Download nimbuzz in nokia n900
Hi you can download Nimbuzz from the Ovi store on your phone, Or you can go into settings, connectivity, USB and select Nokia Suite as default.
Plug your N900 into a laptop or pc via usb and you will be prompted to install.
Easiest way is through Nokia's Ovi store. If you dont have the store client on your N900 here is a link for Nimbuzz, Ebuddy etc
http://en.softonic.com/s/nimbuzz:phones/device-nokia-n900-1224
Hope this helps
Mar 05, 2012 | Nokia N900 Smartphone
I forgot my reset code
- To unlock you Nokia N900 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Aug 30, 2011 | Nokia N900 Smartphone
Hello there I have a problem with my nokia n900 memory. I cant save anything in my phone nor can i open saved items. When i go to settings, it says memory card is corrupted. But memory for installable...
hi there!
first thing to do is to powercycling the phone (turn off, remove battery, simcard, memory card) leave it like that for 2mins, put everything back in. if the same error occurs, try putting that memory card on another phone, if it works fine there, the phone itself maybe the one having problems. to make sure, try putting another memory card on that phone, if its all ok, they its just having a hard time reading your memory card (clean the gold contacts of the memory card by damp cotton buds, not dripping wet ok?) . if your memory card dont work w other phones, it needs to be replaced. if the phone wont read any other memory cards, bring it out for repair already and keep your memory card until phone is fixed.
Apr 12, 2011 | Nokia N900 Smartphone
N900 i forgot lock code
just go to the authorised service center and tell them to upgrade the firmware. that's it your lock code will be reset to 12345. dont worry
Jan 19, 2011 | Nokia N900 Smartphone
I forget my nokia n900 security code how can i reset it?
when i restart my nokia n900 its show us security code but i dont know what is the security code
Dec 15, 2010 | Nokia N900 Smartphone
How to get serial no. for Nokia N900
Try typing this in to get the serial number:
*#0000#
Feb 27, 2010 | Nokia N900 Smartphone
Cell Phones Logo
100 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
