Question about The Jockey Club Information Systems equineline.com Free 5Cross Pedigrees
When is my next stay at Jockey Club? - The Jockey Club Information Systems equineline.com Free 5Cross Pedigrees
I Currently have X9 10 speed rear, but need to replace jockey wheels. are these interchangable with X10 or XX?
Replacing jockey wheels is one of the easier tasks on a bike. You will two standard, 11 tooth jockey wheels. Investing in metal ones with ball bearings is a good idea. Use an aallen key to remove and replace one at a time, taking particular attention to the way the CHAIN goes around each jockey wheel.
Mar 16, 2013 | Sram X9 Crankset 2x10 w/Bash for GXP
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need unlock code for tornado jockey because I can't find a free full version download.
ok if WildTanget is the (MAIN) website for tornado jockey.... um... i want it too... and im gonna try this TOO.. in a minute but um... it MUST PROBOBLY say what the code is on the game case. so.... go online type in tornado jockey. game case. (code) it MIGHT WORK! i dont know though... so dont get ********** at me if it does'ent!!!!!! i tried my best to help!!
Feb 22, 2012 | Origin Tornado Jockey for Windows
What does the small screw next to the higher jockey wheel adjust ?
Why limit the question or answer to just one screw?
It's for body tension. Like the B-Screw on other derailleurs.
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
Jun 27, 2011 | Campagnolo Record Carbon 10 Speed
Can't get my headphones to work on my reloop digital jockey 2 Master edition.
http://www.reloopdj.com/product_info.php/info/p483_Reloop-Digital-Jockey-2-Interface-Edition.html do you have the que set to the side you want also the gain/volume theres there site with the manuals and over view that should give you more then enough knowledge happy djing
May 05, 2011 | Reloop Digital Jockey 2 Interface Edition
Several problems here... Jockey doesn't give me gifts anymore... My Smurfette which I paid 30 smurfberries for doesn't "give love" anymore. My snails and my caterpillar which I paid 20000 for in...
Did you play with the date settings of your device? If you did so, then Jockey, Smurfette, snails and caterpillars will not give you gifts/xp's until the very next day of the latest date you have set your device to be.
Mar 11, 2011 | Smurf Village Send Smurfs
Were is the spring tension eye on the body of the
Its located next to belt @ the bottom of drum. Round plastic section wheel, spring is attachted to this
Apr 05, 2010 | Dryers
Took the jockey wheels off and cleaned it all, but now after refitting the jockey wheels the lower arm has no tension causing the chain to hang low and slack. What have I missed when refitting the jockey...
Did you also remove the derailleur from the bike to do this? When you put it back on there's a tension screw that normally sits on a flat tab or portion of the right dropout to keep the entire assembly rotated toward the rear of the bike.
Or just go here. Pictures speak louder than words.
http://www.parktool.com/repair/readhowto.asp?id=64
Feb 22, 2010 | Sram X.7 Rear Derailleur
Parked car after getting home from work and it want start the next morning. I had an oil change and got my tires rotated and balanced a week earlier and it was doing fine. I checked the oil and it was fine...
Does the starter turn the engine over? If not, the battery may be discharged from leaving the lights on or a stuck-on door light switch? If so, put a battery charger on it over night and check for lights anywhere staying on (trunk, under-hood, or jockey box too). Hope this helps.
Jul 06, 2009 | 2004 Dodge Neon
The Jockey Club Information Systems equineline.com Free 5Cross Pedigrees Logo
80 people viewed this question
Top The Jockey Club Information Systems Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a The Jockey Club Information Systems Facebook App Expert? Answer questions, earn points and help others
