Question about Toshiba Office Equipment & Supplies
Toshiba e-studio 650 suferring code cd1 appears while copying start pls solution
    Problem Solver:
  • 10 Answers
CD1 is a brush lock, check the cleaning unit and clean it out, check gears on the back of cleaning unit that rotate the brush.
Posted on Jan 04, 2015
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
didi2005
  • 524 Answers
SOURCE: How to determine what error codes for failure on Toshiba E-studio
Press "Clear+8" and u will see the error code.
Posted on Mar 02, 2009
didi2005
  • 524 Answers
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Posted on Mar 06, 2009
didi2005
  • 524 Answers
SOURCE: toshiba e-studio550 service code CD1, PLEASE help me
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Posted on Mar 10, 2009
didi2005
  • 524 Answers
SOURCE: toshiba e-studio 160, c56 error code.. how can i
C56 indicates Communications error between the PFC and the CPU on the main PWA. What u can do:
1.Check if the connector CN36 or CN35 on the relay PWA is disconnected.
2.Check if any conductor pattern (PFRXD, PFREQ, PFACK, MACK/PF, PFTXD, or MREQ/PF
between the IC, IC2 and CN36) on the relay PWA is open- or short-circuited.
3.Replace the relay PWA.
4.Replace the PFC PWA.
5.Replace the main PWA.
Posted on Jan 25, 2010
Toshiba e-studio 650 have problem with adf that is when feeded a code c85 appeared
Unplug the computer for a full minute. Take out all paper then put it back in and plug it back in.
That doesn't work call or contact Toshiba.com
Dec 14, 2014 | Toshiba E-studio 550 650 Compatible Copier...
Error code CF70 on toshiba e-studio 600
toshiba e studio600 error codes cf 70
Jul 20, 2012 | Toshiba E-STUDIO 650 Copier
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
I have a Toshiba E-studio 650 with a C46 error code.
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
Jan 10, 2009 | Toshiba E-STUDIO 650 Copier
Cleaning corona wire on Toshiba e-studio 810
Clean with an eraser by rubbing back and forth ( careful it can snap)
use a tissue w/ water
Jul 16, 2008 | Toshiba E-STUDIO 650 Copier
52 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
