Question about Ricoh Aficio Office Equipment & Supplies
Ricoh aficio 1027 print black one side - Aficio Ricoh Office Equipment & Supplies
    New Friend:
    Problem Solver:
  • 6 Answers
Yor drum life may be expired plrase replaced with same opc drum new
Posted on Dec 09, 2014
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 4 Answers
SOURCE: Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Posted on Dec 05, 2008
SOURCE: How to set up my Ricoh Aficio 1027 to be a scanner?
NECESITO QUE POR ESPAñOL ME FACILITEN LAS INSTRUCCIONES DE COMO MANEJAR ESTA FOTOCOPIADORA
Posted on Jul 11, 2009
  • 22 Answers
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
SOURCE: SC543 ricoh Aficio 1027
• Fusing thermistor defective or out of position
• Fusing lamp open
• Fusing thermostat open
• Poor connection of the fusing unit
Inspect all the elements before mentioned, soon presses total clear (Yellow Key) 1 0 7 and Maintain pressed clear stop key (orange key) more tan 3 sec. Enter SP 5-810 (SC code reset),
select execute, select close. Exit SP mode, turn the main power
switch off then on.
If the problem continuous the problem can be in the Power supply board, can be defective.
Posted on Sep 02, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Afico 1027 Printer not printing all the pages
I haven't seen such problem in this printer
Anyhow uninstall the printer software and reinstall it
You might have PCL6 driver
Try RPCS Driver from Ricoh Web
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Driver af1027 for scanner microsoft x764
Good afternoon from Chicago, shiva262,
I'm not sure from your post above, but it appears that you are looking for a driver for your Ricoh Aficio 1027 All-In-One Laser Printer. If that is in fact the case, try the following steps to resolve your problem:
1. If your Ricoh Aficio 1027 All-In-One Laser Printer is connected to a Windows-based PC, use Windows Update to try and locate, dwnload and install the correct driver software.
2. Navigate to the following links and follow the instructions:
http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio1027.pdf
http://www.ricoh-usa.com/downloads/popup/popup_manuals_drivers_download.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x1022_27/x1022_27en.htm
I hope these are helpful in solving your problem. Good luck!
Regards,
Enolram
Mar 01, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 will not print multiple pages or multiple documents. Once restarted it will print the files. But then does it again once you try to print files again and you have to restart it. Worked...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Nov 04, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
