Question about Indesit W 123 Front Load Washer
The machine door wont open after it finish the wash cycle
I turn off and on again
    Problem Solver:
  • 9 Answers
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Posted on Dec 07, 2014
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
All the display lights are on and the door won't open but the cycle is not finished
inbuilt lid safety switch wont let the door open till wash cycle is complete and drum has stop all motion
if you cant open the door at all after cycle ends
turn off at the wall
if no better
could be a timer fault or faulty lid switch
May 31, 2016 | Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
Door Locked and wont open
Mine is crazy too! Sometimes, if I open the soap dispenser it will open, othertimes not. Sometimes, if I pull up on the big, round knob (that you use to turn on the cycle), because it gets stuck down. Once in awhile, I just put it on the last 2 minutes of spin cycle again.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
It does not open
turn the machine off at the mains, after two minutes the door should release from the auto lock, but your pcb (printed circuit board) is knackered start saving.
Oct 15, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
490 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
