Question about Cell Phones
My reset button on the outside of my d2-721 tablet will not respond, for a hard reset. Can the face cover of tablet be removed and repair reset buttom because it appears to be stuck way inside the tab
D2-721 tablet, S/N: H721GWH1304
  • 46 Answers
SOURCE: Opening case of Dell 1907FP to resolve stuck power button
Go here for an instrucional video on opening the cases on DELL monitors.
http://www.lcdrepair.us/Installation.html
Posted on Jun 21, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
ThndrChld's suggestions are great but way too complicated. all you need is a flat head screwdriver. the front bezel/frame/whateveryoucallit can be removed without taking the backside off at all.
the reason the power button gets "stuck" is because it is set off centered from the sensor on the chip underneath it and it relies on a little protruding arm to press down on the sensor...this arm has broken off. button is not really "stuck." its a stupid design flaw by dell or whoever they contracted to make the monitor.
take the screwdriver and just stick it into the seams along the side of the front frame (black frame) and wrench side to side, twist your wrist, etc, to open. you will hear creaking and cracking but thats ok and doesnt damage the monitor at all (though you may create scratches and dents in your casing), its just the clips and snap ins coming loose.
here is a shot of it opened. the chip is held in by 3 very small screws. there is nothing you can do about the power button being broken.
(see this pic shows only front frame is pried open, nothing else) 1086a3b.jpg
the way i circumvented this broken power button is to drill a hole directly through the bezel/frame to the chip itself. i turn on my monitor now with a toothpick (i dont suggest using a paper clip as i first did in this shot, it will scratch up the metal on the chip). you can see where the paper clip is inserted and shows that the sensor on the chip is offset from the power button.
do this or take it into a shop and pay money =). who cares about a nasty looking front bezel, at least my monitor still works.
Posted on Apr 07, 2009
  • 345 Answers
SOURCE: if i press the reset
Here is user manual that explains about this d-link. Network storage servers are just enclosures that you add a hard drive to to be able to use it on network. per this d-link manual all the reset button is supposed to do is reset network storage its self. I would read on it a little just to be sure. Hope this helps.
Posted on Mar 13, 2011
Why is my Next book frozen?
a repair might cost more than the tablet did
if it no longer responds to your finger maybe broke digitizer
you could do a factory reset. and hope it responds to your finger.
Nextbook Android Tablet Hard Reset
Jul 22, 2015 | Tablets & eReaders
My Tablet has been charging for day and I cant get it to turn on, what do I do?
first try pushing reset buttom
or a hard reset hold power button and tap vol up
Jun 15, 2015 | Visual Land Prestige Pro 7D 7 inch Tablet...
I have screen which says no command. recovery system v4.4.2
If you have the capiblility, carefully unsnap the back cover and disconnect the battery plug. Carefully reinsert the plug and replace the back cover. The tablet will now be off.
Try to reset the tablet by pressing and holding the power and volume (+) button until the tablet fully resets itself. After the reset, hopefully you will be able to use your tablet again.
If you are not comfortable removing the tablet back cover, contact a local phone and electronics repair service for assistance.
Mar 05, 2015 | Tablets & eReaders
I have responded to all of your requests to no avail. I can only retype this simple request so many times. once again my reset button on the outside of my d2-721 tablet will not respond, for a hard re
If the button does not respond it might be broken. If you have a slip case on your tablet it might be stopping you from fully depressing the button.
Dec 10, 2014 | Tablets & eReaders
I have locked my self out of my tablet how can I reset and use new password
Try holding the on/off buttom and the volume buttom down at the same time til you get a reading across the screen promote you what to do next. This should reset everything and let you back in. ( make sure you hold both the up and down at the same time on the volume) good luck and i hope this works just about all eletrice have a soft and a hard reset.
Nov 30, 2014 | Proscan 8 4GB Android 4.1 Tablet
Why in bluetooth keyboard cover for Lenovo Tablet Yoga 10 the "Delete" buttom does not working?
Could be something as simple as dirt under the button, get yourself some electronic switch cleaner and spray under and around the button. Always keep keyboard clean.
Jul 21, 2014 | Lenovo Yoga 10 Bluetooth Keybrd Cover
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Aug 18, 2012 | Craig CMP741d Tablet
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
