Question about Garden
Oiler on mac3516 not suppling oil to bar - Garden
    Problem Solver:
  • 4 Answers
Take the bar and chain off, clean any sawdust and grime from where the bar meets the body of the chainsaw. Make sure the oil tank is full but don't reassemble yet. Start the chainsaw without the bar and watch to see if any oil is coming out of the little hole or slot above the bar bolts. Check that it isn't clogged with muck. If this bleeds oil then check the bar which has an oil hole that matches up with the oiler, this could be clogged. Blow out with compressed air, also run a piece of hacksaw blade around the groove where the chain sits in the bar to clear debris and blow out. Good luck.
Posted on Dec 07, 2014
SOURCE: location of bar oiler adjustment screw on p4018wt
THIS WORKED FOR ME....I have a 2014. I've had that problem for quite awhile. I finally decided to try to fix it. I took the bar and chain off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain bar bolt. Once I found the hole, I then drained the oil tank, and then using the air pump, blew out the hole from the blade area to the tank, leaving the oil cap OFF. Upon refilling the oil tank with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the oil; tank empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Posted on Apr 02, 2009
dontbother10
  • 2220 Answers
SOURCE: bar oiler does not work
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Displays all components and can be used as disassembly guide:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
As you requested
This is clutch removal (yours is similar):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it). HTH
Lou
Posted on Feb 03, 2010
dontbother10
  • 2220 Answers
SOURCE: I Have a poulan brand chain saw that the bar oiler
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
An example of a Poulan “PP220 Gas Chain Saw Type 5” IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for the oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly.
It has an outboard clutch use this and the IPL as a guide for removal. R² Drive Link Outboard Clutch by Drivelink.blogspot.com
If your saw is not a Type 7 an IPL for all Poulan chainsaws can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 04, 2010
  • 4088 Answers
SOURCE: husqvarna 345 bar oiler
Remove the bar and chain. Start the engine and observe the oil delivery port in the side of the engine case. At a fairly fast speed, the oil should ooze out of the port. If little or nothing, check the pump, lines, and in-tank filter. If ok, clean the bar drive-end holes of sawdust and dirt, especially the small passages that go from the large holes out to the chain groove. Clean the entire groove and the outer end sprocket. Reassemble and test the oiling by running the bar tip at speed in front of a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Posted on Apr 09, 2010
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
Feb 19, 2013 | Garden
I need to know the oil gas ratio, and about chain
Hi ccollins529...
Normally a 50 to 1 mixture is fine...1 pint 2 cycle oil to 6 gallons of gasoline.
Use "bar and chain" oil on the bar, this is an oil blended for the chain and bar.
If yours has an auto oiler you will put the oil in the bar/chain oil container.
If you do not have an auto oiler,use a hand oiler to lube the chain when needed.
Please take time to rate me
Aug 28, 2011 | Garden
I have an MS660 and the bar oiler has not functioned on my last take of fuel. is there a way to trouble shoot the oiler problem without taking it into the shop. I hate to loose a weekend of cutting.
Start by removing the bar and chain and start the saw with a full tank of fresh Stihl bar oil.
If you are or have used a low grade oil or used oil you may have worn the oiler out.
Watch for oil to come out of the oil port.
If it does at a steady rate of about 10-21cc per min at 13,000 rpm or about 1/2 oz. per min then the bar is clogged with saw dust and needs to be cleaned.
If oil does not come out of the hole you will need to trace back the problem. the oiler is under the clutch. To remove the clutch remove the c clip that holds clutch drum ,washer and bearing remove those comonents and you are to the clutch. the clutch comes off reverse threads (right to loosen)
The problem is that the engine wants to turn, so remove the spark plug and put something soft in the sparkplug hole like 2 ft of starter rope. the clutch will come off and you will be able to see the oiler gears and hoses. worst case you will need a new oiler which is held on with a few t-27 screws.
Again I stress the point of good oil.
find parts at a local dealer like www.arcolawn.com
joe
Feb 19, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Oil pouring out of mac3516,chain oiler
You have my condolences.
Your saw is here, which one?
Chainsaws 32cc-35cc-38cc Anti-Vibe
I chose "22-600035-18" as an example , it follows (more detailed print - may not be your saw):
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
McCulloch IPLs (all)
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I know it is not plugged but this may also be helpful.
Oil System Plugged:
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Mar 22, 2010 | McCulloch Garden
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 03, 2009 | Garden
Chain oiler does not seem sufficient
The chain oiler injects oil into the rear of the bar where the cover mounts over the sprocket. Take the bar off and clean out the oiler hole. There is usually some buildup of sawdust in the hole. Clean out the grove that the chain guide runs in all the way around the bar. You can see the injector nozzle under where that bar was when you removed it. Sometimes there is an ajusting screw there to increase oil flow.
Sep 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chainsaw oiler leaks oil out case and no oil on chain
Take the bar and chain off--run the engine--the oiler port from the case should discharge some oil. If none, you have trouble with the oil pump or the tubes to and from it. The oil tank may be leaking at the tank opening for the pickup tube. If oil appears at the oiler port, then there may be dirt/blockage within the oil passages in the bar end. Clean with compressed air.
Jun 28, 2009 | Garden
Ryobi 40 cc bar oiler not working
hi customweldi
check the oil filter,the oil line ,the oiler and the worm gear.Clean the bar and the oil hose.
the best savumihai71
Nov 30, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
