Question about Comfort Zone Heating & Cooling
My # CZ2011O Comfort Zone Infrared Heater ONLY gives low heat on Energy Saver and High Heat functions and NO heat on the low power function. Does this mean the quartz bulbs are bad?
Is there a 'manual' reset on this unit? The manual shows LITTLE. Can the bulbs work at half efficiency or maybe a capacitor problem?
  • Barry Sarvis Dec 09, 2014
    There is no 'error' shown on device.
micromatikal
  • 2777 Answers
SOURCE: I have an AO5 error
This indicates a power fault inside the actual heater. Have you tried unplugging the heater, letting it sit for a good 2 minutes, and replugging it back in? If the problem persists you will unfortunately need a repair. Please let me know if you need more information on this. You can also contact comfort zone, the manufacturer, located in Canada, at 780-420-6572.
Thanks so much for the question,
Tim
Posted on Sep 09, 2010
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
SOURCE: My comfort zone infrared hearter
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Posted on Nov 24, 2010
heatman101
  • 43501 Answers
SOURCE: My edenpure heater turns on
If you have continuity through the bulbs then the next most likely thing is the thermostat...
If you check here you will see that they sell the t-stats so I would check that out...
Check for continuity through the t-stat and if there is none then you know what to try..
heatman101
Posted on Dec 04, 2010
  • 4736 Answers
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Heat but no fan
Temperature fan switch needs replacing...make sure there is power to it.
Dec 17, 2013 | Comfort Zone Infrared Quartz Heater
Maytag dishwasher MDB6160AWB "Clean" indicator
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Maytag Dishwasher
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
My comfort zone 1500wo isn't cycling on and off. Do you know what is happening & how to fix it?
Hi, I just got my comfort zone 1500w and same thing. I called Comfort Zone this morning at 1-800-221-6895, they are most pleasant and helpful. She said it was because I had it on the energy saving mode. When it is set to that the fan runs continuously and never shuts off. She said to put it to the low or high setting and once the temp is reached, it will automatically shut off. Then when the temp drops it will turn on. Cycling off and on doesn't work with the energy saving function - she couldn't really give me an explanation for it just said don't use it if I want it to cycle off and on. Hope this helps.
Dec 22, 2010 | Comfort Zone NEW 09 Electric Portable...
Once reaching the set temperautre the heater will not shut off
If it is on the energy saving mode it won't shut off. You need to set it to the high or low mode to get it to cycle off and on. This is what COmfort Zone told me when I called them. Hope this helps.
Nov 25, 2010 | Comfort Zone NEW 09 Electric Portable...
I'm considering a Canon D340 multi-function copier and notice it has an "energy saver" button rather than an on/off switch. After making a copy, the panel goes dark. If you select the "energy saver"...
There is still power to the machine. It is simply waiting to be used. These machines use an "instant on" fuser. These fusers (the part that heats up to fix the toner to the paper) do not use a heater lamp that needs to stay hot. They use a thermal head that can heat up within a few seconds so no need to stay on and hot all the time.
Jan 07, 2010 | Canon PC-D340 All-In-One Laser Printer
Heating & Cooling Logo
57 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
