Question about Konica Minolta bizhub Office Equipment & Supplies
I cannot print from my konia minolta c360 series machine. The error showing c3201
    Sergeant:
  • Konica Minolta Expert
  • 224 Answers
C3201 Description Fusing motor failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the connector between M3-PRCB CN11 for proper connection and correct as necessary. 2 Check the loading status of the fusing unit drive, and correct the error as necessary. 3 M3 operation check PRCB CN11-9 (REM) PRCB CN11-12 (LOCK) J-6. 4 Change M3. 5 Change PRCB.
Posted on Dec 11, 2014
4 Suggested Answers
  • 158 Answers
SOURCE: volume track (e.k.c.) error on Minolta C350 Bizhub.
go to the properties of the driver and click on printing preferences and click on authentication/account track and the user name and password that you use to make a copy will have to be enter in this area to to print
Posted on Dec 02, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
  • 158 Answers
SOURCE: an error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Posted on Feb 06, 2013
BIZ HUB C 360 AFTER 5 PRINT ERROR SHOW C 2558 OPEN FRONT DOOR & CLOSED , COPY QUALITY IS OK
Looks like Black Developing unit malfunctioning.
Replacement is the permanent solution..
Dec 17, 2016 | Konica Minolta Bizhub C360
Konica Minolta C360 Series machine showing message on home screen: Tray 2 cannot be used currently How do we undo this so that we are able to print to either tray 1 or 2?
First remove the paper from behind the draws, that is probably what cause the problem. Then you need to get into service mode. Utility/counter, details, stop 00 stop 01, password 9272927292729272, system one, trouble isolate,
Find the draw causing the issue then your going "SET" then power off WAIT TEN SECONDS power on then go though the entire procedure again get to the screen and select UNSET. Power off WAIT Ten seconds power on. Your draw should show back up.
Set
• "Unset" is Default
• After changing the setting, touch [Decision] and turn the main power switch OFF and ON to make the new setting effective.
If the not get a tech out to look at the problem
Nov 10, 2015 | Konica Minolta Office Equipment & Supplies
Can use tonner powder from c220 container to refill a biz hub c550 container to finish up my printing?
WHAT!!!?? C'mon you know the answer to that question... Or at least I hope you do... That toner is ONLY compatible with other like models in that series. That includes the: C220 C280 and C360 models.
Toner is specifically formulated for certain saturation and transfer static tolerance ranges. Adding another toner from another model series could cause serious damage to the parts in your machine. Not just bad quality...
I suggest you find the money to simply buy new cartridges. If you have a bunch of extras for a C550, then sell them on places like Ebay or Amazon. But don't use them in your C220.
Otherwise, you will be BACK here in a short while asking why your machine is printing really terrible and flashing errors codes...
Aug 24, 2014 | Konica Minolta bizhub Office Equipment &...
THE KONICA MINOLTA C360 COPIER SHOWS ERROR CODE C6103
• Scanner home sensor (PS201)
• Scanner motor (M201)
• Scanner relay board (REYB/SCAN)
• MFP board (MFPB)
Scanner is located under the big glass. reset open close right door
Jan 21, 2014 | Konica Minolta Office Equipment & Supplies
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
Error code c3201 bizhub c203
Fusing motor failure to turn remove the fusing unit. Check for proper operation. If the orange rollers are chewed up replace the fuser unit
try this place for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Aug 02, 2012 | Konica Minolta Bizhub C203
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
