Question about Optoma EP739 Multimedia Projector
The lamp exploted in less than 30 hours of use, replaced an exploted in 4 hours, replaced and exploted in 5 minutes what can I do?
Replacing lamps
  • 55 Answers
Is it the correct bulb? Or recommended bulb? Try a higher wattage or lumens. I'm not sure what the lamps in the projectors are called, but check on the wattage and lumens.
Posted on Dec 07, 2014
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
How to replace lamp
hi,
1.Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
turning the power off.)
2.Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it.
Take the new lamp out of the box.
3.Remove the Front Panel Cover.
4.Pull out the lamp.
Loosen the screw on the lamp cover with a coin or similar object to
remove it, slide the knob to left, and then pull out the lamp cover.
Loosen the screw that holds the lamp, then pull out the lamp.
5.Reattach the lamp.
Place back the new lamp and tighten the screw.
Replace the lamp cover, slide the knob to right till the up arrow down arrow mark
matches, and then tighten the screw.
6.Reattach the Front Panel Cover securely.
ok
Feb 26, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV comes on with a good clear picture and about 30 to 40 sec goes off.
The tv projection lamp have not been replaced in this tv like the last 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours a day?Yes,than the tv projection lamp life is over.The tv projection lamp,require replacing.
Oct 18, 2010 | Samsung HL-S5087W DLP TV
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Unit goes off after about 30 minutes, possible overheating ?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600826A.Have a blessed one!
Mar 29, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
InFocus LP130 Projector has intermittent power off
go into the menu to find out the lamp hours. it could be the lamp, but if the projector shuts down and not just the lamp, there is either an overheating issue, or a power supply issue.
Mar 07, 2009 | InFocus LP130 Replacement Projector Lamp -...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Replacing bulb
hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Dec 01, 2007 | InFocus In Focus SP-LAMP-021 Replacement...
TV Shuts off and on by itself
this problem has been seen and repaired at Sony from a bad lamp.Especially if lamp has lots of hours of use.Try a new lamp as see what happens.I have access to Sony docs and this is what I read..goodluck
Nov 30, 2007 | Sony KDF-E55A20 55 in. LCD Television
Optoma EP739 Multimedia Projector Logo
81 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
