Question about Garden
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Replaced drive chain drive belt and checked clutch thickness half me of wear could clutch be glazed
  • Garden Master
  • 2,321 Answers
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Posted on Dec 08, 2014
3 Suggested Answers
SOURCE: Have a Greenfield Evolution 2000
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Posted on May 03, 2011
  • 640 Answers
SOURCE: I replaced both belts on
Likely the belt is mispositioned or somehow in a bind.
Posted on Aug 22, 2011
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
Tip
Mechanical System Troubleshooting for Stairmaster 4000PT Stepper
  1. Remove the side covers. WARNING: TO REDUCE THE RISK OF INJURY, DO NOT OPERATE THE MACHINE WHILE THE COVERS ARE REMOVED. DO NOT DEPRESS OR RAISE THE PEDALS WHILE ANYONE'S HANDS ARE INSIDE THE MACHINE.
  2. Remove the Poly-V belt and inspect the belt for cracks, fraying or any other unusual or excessive wear.
  3. Spin the alternator pulley to check the bearings. Replace the alternator if any clicking or grinding noises are heard.
  4. Inspect the alternator pulley for wear.
  5. Tighten the transmission pulley set screw to the flat side of the transmission output shaft.
  6. Remove the drive chain and inspect the chain for frozen links. Replace a chain with frozen links.
  7. Tighten the transmission drive sprocket set screw to the keyway in the transmission input shaft.
  8. Spin the transmission drive sprocket input 1 complete revolution. The transmission pulley output should turn 19 revolutions. Replace the transmission if any clicking or grinding noises are heard during rotation or the drive ratio is not 19 to 1.
  9. Remove the step chains and return springs from the main frame of the machine.
  10. Inspect the step chains for frozen links and the springs for corrosion. Replace a chain with frozen links and replace a corroded spring.
  11. Make sure that the step chain connection points pivot freely and have no vertical play.
  12. Remove the pedals, pedal arms, and leveling arms and lubricate according to the maintenance section of the manual.
  13. Verify that the clutch sprockets of the hub assembly spin freely in the forward direction and lock in the reverse direction.
  14. Inspect the hub assembly for wear. The drive shaft sprocket should not move up and down or side to side.
  15. Clean and lubricate the drive and step chains with 30W motor oil.
  16. Reinstall all parts, ensuring the proper tension of the Poly-V belt and the drive chain.
Stairmaster Mechanical System Troubleshooting for 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
Aug 26, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
My swisher25hp-60 in.cut barely moves going forward
Was it working correctly earlier or is this your initial operation?
According to the product manual for "loss of drive":
1. Bypass linkages in the bypass position
2. Hydro belt worn, damaged, or broken
3. Idler spring loose or broken
1. Make sure that the bypass linkages are in
the drive or engaged position. Located at
the rear of the machine. Refer to decal on
the rear of the unit.
2. Replace Hydro belt.
3. Replace Idler spring
Apr 16, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
What causes the Clutch drum gear that drive the chain to go bad ? my chain eats a groove all the way through it aftr about 12 hrs of cutting I have replaced it 3 times now.
The chain you should be using should be a .325 pitch and not a 3/8.
Never over tighten the chain, it will wear and stretch with time, which is why you should regularly check the chain tension. To get it right you should be able to lift 2 drive links clear of the bar. The chain will naturally wear groves into the spur sprocket, there is no conversion to a rim spricket for this model. Rim sprockets allow the chain to move along the sprocket easier and takes the wear away form the clutch drum.
Oct 11, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
What do i need to do on the 8000km service
Drain and replace all fluids, including brake fluids.
Check brake pad thicknesses and disks.
Check primary chain tension, 5/32" play maximum.
Check clutch adjustment.
Check drive belt tension and for damage.
Check throttle adjustment, if any.
Check lights and tyres.
Check exhaust for leaks.
Ride safe!
Dec 23, 2010 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Garden Logo
496 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
