Question about iHome Audio Players & Recorders
Why is the display of my ihome no longer lit?
Unplugging and plugging it in Shaking it around
How to use ihome multimedia 182 keyboard BL-K601?
Try unplugging a re plugging. Keyboard operation is a basic and crucial functionality for computers and most of the time drivers are automatically installed when plugged in.
Apr 17, 2016 | Dell Computers & Internet
Sync ihome wireless keyboard
Say the device you want to sync your keyboard to is an I pad.
Follow the I pad's normal Bluetooth pairing procedure. Around the same time, slide the switch on the back of the ip2101 from OFF to ON and then press the black button to the left of that switch. When the I pad recognizes the ip2101 keyboard, the I pad will display a pin number and instructions to type that pin number on the ip2101 keyboard and hit the enter key on the ip2101.
Dec 22, 2013 | iHome Ih-ip2101
Hi I have an iHome alarm clock/radio that has an ejectable outlet for the iPhone/iPod/ etc and after one drop to the floor, the piece that reads iHome broke off and the ejecting piece does not push out by...
sadly this devices are no longer sold
you should try to find a damaged iHome and use for replacements or find a used one to replace your actual device
ihave an iHome too, and i had made some tricks to keep it working
Mar 22, 2011 | Audio Players & Recorders
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Jul 30, 2010 | Element Electronics FLX-1910 19 in. LCD...
Display is all lit up every digital display is maxed and I cannot reset it.
try unplugging the unit for ten or fifteen minutes and then plug it back in again. That will reboot the processor that controls the display. If that doesn't work, you'll probably have to have the display replaced or at least checked by a professional for water damage or bad connections.
Mar 14, 2010 | LG LRFD25850 French Door Refrigerator
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Dec 25, 2008 | Apple iPod nano
43 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
