Question about Garden
Need the routing diagram for a Poulan 295 pro of the fuel and throttle lines
    New Friend:
  • 35 Answers
It appears there is only one "fuel line" from your fuel tank to the carb. Not sure what you mean by "throttle lines"....linkage, maybe? Anyway, here is a diagram of the parts; http://www.poulanpro.com/ddoc/POUI/POUI2000_USen/POUI2000_USen__530088792.pdf
Posted on Jan 02, 2015
dontbother10
  • 2220 Answers
SOURCE: I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Posted on Oct 12, 2009
dontbother10
  • 2220 Answers
SOURCE: I need the fuel line routing or diagram for a
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Posted on Oct 23, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Posted on Oct 28, 2009
  • 6 Answers
SOURCE: Poulan Pro 295 won't keep running.
pull the black dust cap on top there are three screws going down, the idle screw is on the left side (if you were holding the saw) near the top of the carb it has a spring around it. the 2 weird screws under that are the mixture screws hi and low rpm you really shouldn't mess with those unless your sure of what your doing. if that doesn't work there is a really small hole ( and I mean small) in the bottom of the carb for a diaphragm if that gets clogged it runs bad, also vibration can loosen the cylinder bolt turn the saw upside down and there are (or should be 4 bolts) make sure they are tight if one already rattled out take the one kitty corner to Lowe's or a hardware store and get a replacement.
Posted on Mar 06, 2010
  • 4088 Answers
SOURCE: Poulan Pro 295 46cc chainsaw that won't start
Does the spark plug get wet with fuel when pulled through? If dry, try spraying a little starting fluid in the plug hole and reinstall the plug. If it pops at least once, you have fuel delivery problems--look for hardened/ cracked fuel lines. Clean the muffler arrestor screen. When the muffler is off, check the condition of the piston skirt and cylinder wall for deep scoring or obvious wear. Make sure the primer button (if equipped) is filling with fuel when pumped a few times. If it doesn't, make sure the bulb is not hard or cracked and check the lines going to and from it. Check the carburetor bolts and nuts for tightness. The fuel filter in the tank could be plugged, fish it out and check. If you have checked all these items, it may be time to clean and rekit the carburetor. Hope this helps!
Posted on Mar 08, 2010
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
Need diagram how to reinstall carburator on poulan 295 pro chainsaw
partstree.com or jacksmallengines.com I dont know if there ever was a service manual. I havent seen one
Mar 25, 2014 | Garden
I need a diagram of how to route the throttle line on my Poulan 225 Pro chainsaw. Where can I get one?
Here http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137250.pdf
Jun 13, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Am replaceing fuel lines think i might have them crossed need diagram
There is an illustration on the link that should provide what you ask.
The IPL for your saw can be here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Try PP4620 AV Gas Saw. HTH
Lou
Jan 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Lou
Oct 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
549 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
