I am trying to hang a quantum qtc37a5f on the wall, when I remove the base stand there is still a large tube hanging down from the bottom of the t.v. How do I remove that?
Orbixx
  • 133 Answers
SOURCE: removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Posted on Sep 07, 2007
SOURCE: Can't get base off 26" Insinia 720p
On the back of the set you will see 8 screws just above the stand; remove the screws
and gently slide the stand out. Wiggle it alittle and the stand will come out.
Remove the metal tab you just pulled out by removing the screws at the bottom of the tab (attached to the pivit joint) place the tab back in the bottom of the set( same place you removed it from) and re-install the screws ( don't over tighten them). You are done.
I had the same trouble with this set and the tech support was of no help. Good Luck.
Posted on Sep 08, 2008
  • 2336 Answers
SOURCE: i want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
Posted on Jan 02, 2010
  • 103 Answers
SOURCE: How do you take the base off the bottom to hang
On the back of the tv located at the very bottom where the stand meets the base of tv there are from 4 to 6 screws that hold it in place. I am including a link to the tv's manual. The instructions for the base are located on p.13. If this helps please rate me. I do not get paid but like to help.
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Posted on Dec 18, 2010
Testimonial: "Thanks for the help... SUPER HELPFUL!!"
  • 39 Answers
SOURCE: How do you remove the bottom stand from the TV set
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Posted on Jan 06, 2011
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
I can not remove the stand..........to hang on wall mount.....
There should be a few philips type screws on the rear of the set at the bottom. There are either 2 or 4 large screws that hold it to the stand. Also, the instructions that come with this model describe how to convert it for wall mounting. Every one of these sets I work on has 4 screws that hold it to the stand and I have to use a long philips screwdriver to get them out before I can begin the repair. Better to have a magnetic tip on the screwdriver for easy removal. Let me know if I can be of anymore help. Good Luck, Russmann.
Feb 01, 2011 | Olevia LT42HVi 42 in. LCD Television
How do i remove the tv stand from a 42 inch flat sreen so i can hang it on the wall
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the tool you will be using to remove the stand remove the screws from the bottom back of the television and remove the stand.
Jan 08, 2011 | Televison & Video
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How can i get the stand off of the tv to hang on the wall?
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Jan 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have an LG 42lh40, I need to remove the stand so I can hang it on the wall. How do Itake the swivel stand off? Can some help?
It straight forward check for all around the base stand for screws,just make sure u check and take out all the screws out.Now,just push the base stand it foward or backward for loosen.Just take it out now.
Nov 24, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I take off the stand? I just hung the TV.
Take the TV down. there are 4 Phillips head screws one the back bottom that hold the stand on. take them out and lift the TV off the stand and hang it back on the wall. be sure to remove the stand screws and not the screws that hold the TV together.
Jan 11, 2010 | Akai LCT42Z6TA 42 in. LCD Television
How do I remove the base stand fro my Neovo F-17,
You need to remove the two plastic covers the cover up the hinges mounting screws, which are attached to the back of the monitor.
Oct 26, 2009 | Neovo F-17 W (White) 17 in. Flat Panel LCD...
I cannot remove the bottom of my cd player. I want to hang it on the wall
Turn the system upside-down and look at the bottom of the stand. It should have arrows saying "Release." Pull the stand in the direction of the arrows, and it should come off.
Oct 03, 2009 | GPX HM3817DT Shelf System
How to take bottom off to hang
You will need to remove the stand metal plate first located below the connection panel. It is held in place with 3 screws. You will have to put on of those screws back into place. Then you will need to remove 4 more screws, two on each side midway between the center and outer edge of the TV. You should be able to lift the TV off of the base.
Jan 29, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
