Question about Chevrolet 2010 Chevrolet Avalanche LTZ 2WD
I have a 2010 avalanche ltz. The service stabilitrak light comes on intermittently yet when I have the code reader hooked up it shows no code. Would it show up in the abs codes?
I've taken all the wheels off and cleaned the connectors that I could find
    Problem Solver:
  • 5 Answers
Hi Their Yes Their is ABS Codes Realated to the Cloc springs.
I would take it to the nearest Dealer they can or should check your ABS codes For free. Hope it helps
Posted on Jan 19, 2015
2010 Chevy Equinox,Check engine light P0017, Service Stabilitrak comes on and the car loses power. Tried checking the EGR to ensure not stuck open and have had no improvement.
DTC P0017: Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation Bank 1
Which engine does yours have 3.4 or 2.8 , 3.0 , 3.2 , or 3.6 L Chevy Colorado P0017 Case Study Part 1
Dec 15, 2016 | 2010 Chevrolet Equinox
I have an 07 avalanche z71. I was driving the other day and the truck went into reduce engine power traction control disable check engine light and service air bag. Now it does it after five miles.
Get a computer diagnostics done and it will likely tell you what is wrong. You can buy readers now for less than $100.00. Otherwise you are really guessing.
Oct 02, 2016 | 2007 Chevrolet Avalanche LTZ
What is making my stabilitrak light staying on
StabiliTrak service light - Chevy TrailBlazer, TrailBlazer SS and ...
forums.trailvoy.com > ... > 02-09 General Tech Q&A > General
Dec 24, 2009 - 11 posts - ‎7 authors
However, the StabiliTrak system seems to be working, as in my area ... If you have OnStar push the button when the Service Stabilitrak light is on have them run a diagnostic. ... 2007 Chevy TrailBlazer LS .... Choose your make. Service Stabilitrak light comes on
Mar 31, 2011
Service Stabilitrak
Mar 27, 2011
very strange thing happend/ traction control light ...
Sep 2, 2010
Abs and traction control light
Sep 20, 2009
More results from forums.trailvoy.com
Feb 09, 2016 | 2007 Chevrolet Trailblazer 4.2
How to fix traction control>
Traction control doesn't shut the engine off. It will shut off the ABS system. Which is for slipping and sliding. You need to have the codes read. You can get code readers fairly cheap now days. But the cheaper ones will not read the ABS system or any other. Just the engine.
Aug 11, 2014 | 2007 Chevrolet Avalanche LTZ
What is stabilitrak chevy
Stabilitrak is a design that lets the ECU and the ABS system share information. If you step on the gas pedal and loose traction, the ABS tells the ECU that you have lost traction. The ECU calculates what it should do to help and usually will ignore your request for "more fuel" (when you step on the gas pedal) and will reduce the power to the transmission until the ABS system communicates that traction has returned. More than likely there is a failure in the ABS system. The problem may be intermittent right now but this will need to be repaired. If you have an ABS code reader please let me know what codes are stored. If not then you will need to send your car in for diagnostis and an estimate for repair, let me know if I can be of any more help, good luck.
Apr 09, 2014 | 2012 Chevrolet Impala LS Sedan 3.6L V6 FFV...
Gear shift Selector stuck
These were known for having faulty brake light switche that would cause that problem as well as cruise control inop. I would check that first. It operates the shift-lock solenoid which releases the shifter. There were also some problems with the ignition switches, but mostly on the gm cars.
Feb 13, 2014 | 2008 Chevrolet Avalanche LTZ
Stabilitrak service comes on and i lose power. could this be the body modularsensor or throttle body sensor.
If you have a cable throttle then not likely, if you look at your throttle body and it is electronic then it could be the throttle body position sensor or possibly the accelerator pedal sensor. Are the any DTC codes present on your truck (check engine lights) cause both of these issues have sensors the will most likely trigger a code light on the dash. If not light comes on I would have it scanned just to make sure it doesn't have any codes stored in memory
Jan 02, 2014 | 2007 Chevrolet Avalanche LTZ
How do you reset the service stabilitrak warning
You would need a repair shop or the dealer that has a scanner that will connect with the body computer. Its different from an engine computer scanner or code reader.
Mar 25, 2012 | 2010 GMC Sierra 2500HD
I have a 07 chevy avalanche and check engine light is on need some kind of sensor anyone know where I can get one or how much they cost?
Do you happpen to know what sensor. It has a lot of them. Have you had it scanned? Autozone will do this for free
Aug 31, 2009 | 2007 Chevrolet Avalanche LTZ
Chevrolet 2010 Chevrolet Avalanche LTZ 2WD Logo
146 people viewed this question
Top Chevrolet Computers & Internet Experts
Richard Warren
Richard Warren
Devon trahan
Level 1 Expert
Jeff Armer
Are you a Chevrolet Computer and Internet Expert? Answer questions, earn points and help others
