Question about Mercedes-Benz 2012 Mercedes S550 Quarter Window Regulator 3t93400o 230 Type; SL550 and SL63, Driver Side Atlanta, Georgia
Solution to non-function of mercedes benz c230 model 2012 .i've tried changing the remote battery but to no avail
I have tried checking the remote battery . but what can i do if i wish to change the remote
  • 7 Answers
SOURCE: Ballpark price on 2007 Mercedes Benz C230 Maintenance B
The dealer near me charges $365 for a 4-cyl, $395 for a 6/8 cyl, or $425 for a 12-cyl. The only actual repair/maintenance you get for that price is an oil change (with Mobil1 and the MB filter, which are CRITICAL, ~$120 on its own) and tire rotation. This makes a lot of people think it's a scam, but really, it's a little steep, but definitely worth doing. The rest of the service consists of a massive inspection of your vehicle covering the following items.
-- Fluid levels
-- Tire tread/pressure/wheel condition
-- Air filter (inc. clean out housing)
-- Cabin air filter (inc. clean out housing)
-- Lubricate sunroof rails, locks, hinges, and seals on body.
-- Drive belt and tensioner
-- HVAC system operation
-- Instruments, cruise control
-- Wipers/washers/lights/horn
-- Windows/sunroof operation
-- Hoses
-- Transmission fluid
-- Brakes
-- Chassis/suspension
-- Driveshaft, inc. flex discs
-- Road test
-- Reset maintenance light
This is actually pretty essential to do, despite seeming like a lot of money for not much work. I have very rarely done one without catching a few things that the customer needs, and often it was a problem that would have gotten far worse had it been left to its own.
Posted on Feb 22, 2009
SOURCE: How to change air filters on 2007 Mercedes C230 Sport
I have '05, both should be similar:
1.Cabin air filter is located above battery on right side against firewall.
Release three latches, remove filter housing, slide old filter out (housing is flexible), insert new
one, reinstall housing.
2.Engine air filter is on the left side of the block (follow intake hose). Cover is retained with six screws
(six point star shape,I belive called Torox, bit/scredriver size 25). Loosen screws (don' t pull all the
way out of the cover) lift cover , and remove old filter. Insert new one, reinstall cover. DO NOT
OVERTORQUE SCREWS! Screw holes in plastic filter housing strip very easily.
Note: Intake hose is very flimsy, one on my car came apart and had to be replaced.
Posted on Mar 29, 2009
emissionwiz
  • 79123 Answers
SOURCE: Mercedes-Benz Transmission Fluid question
the transmission on your MB is sealed with no way to check the trans fluid level,(no dipstick provided for) that is why the report says "sealed". MB did this to stop customers from overfilling there transmissions, which can cause severe damage if not done properly at the correct fluid temp, this requires special test scan tools.
Posted on Mar 30, 2009
  • 19 Answers
SOURCE: How do you reset c230 2007 mercedes benz resetting
Try this, it is the procedure for resetting the ASSIST computer on many Mercs
1...Turn Key to position No:2 in the ignition / steering lock and immediately press AND Hold the button "000.0" (the trip reset button) TWICE within the space of 1 (one) second.
2…Turn the key to position No: 0 in the ignition / steering lock. Then release the button.
3...Press AND Hold the button "000.0" (the trip reset button) and turn Key to position No:2 in the ignition / steering lock. Keep button pressed
After about 10 seconds
the service indicator will reset and an acoustic signal may briefly sound
That should do it....Good Luck…...Let me know if it works?
Posted on Jul 08, 2009
SOURCE: battery is dead and can't open the trunk, even manually
Starter motor on this car is imposible to get to..better find the post forward of the drivers side fuse box in the engine compartment where a bunch of wires come together. This is a positive terminal attach red jumper here put the negative jumper on any bare metal bracket of the engine
Posted on Aug 14, 2009
2000 Mercedes c230 kompressor smart key remote works to lock and unlock car but ignition won't turn
Try another key, if not test the battery voltage. Your cars battery might be low, it needs full voltage to turn the key.
Sep 24, 2015 | Mercedes-Benz Cars & Trucks
How can I get my 2005 Mercedes C230 key to remotely open doors, I have changed the batteries but it will not lock, nor open doors.
Seems like you may have to reprogram your key fob, take it to a place where they cut keys and they will charge you $40 to reprogram it.
Oct 27, 2013 | Mercedes-Benz C230 Cars & Trucks
2004 Mercedes-Benz C230 kompressor warning gauge Battery / Alternator needs to be service.
check your volt gauge on the dash. if it's working properly, then your car is throwing a bad code. if the battery looks as though it's taking more than 14 volts, or less than 10, you have a problem.
Sep 17, 2013 | 2004 Mercedes-Benz C230 Kompressor
Remote key dosn't work till you are very close on my 1999 Mercedes C230
not much if battery changed the key fobs a notorious for going and very expensive to replace about 200 pounds as long as its still working don't worry about it
Mar 19, 2013 | 1999 Mercedes-Benz C-Class
How do I change the cabin air filter in my 1999 Mercedes-Benz C230?
There is a great manual you can order online that provides you with great step-by-step instructions to help you change your cabin air filter for your vehicle. I will attach the link for you here...
http://www.automotix.net/autorepair/diy/buy_access.html?type=init&make=mercedes_benz&model=c230&year=1999
Jul 17, 2012 | 1999 Mercedes-Benz C230 Cabin Air Filter
How much does the 2003 Mercedes-Benz C230 Cabin Air Filter cost?
The 2003 Mercedes-Benz C230 Cabin Air Filter costsbetween $10-$25, depending on the model.
Jul 16, 2012 | 2003 Mercedes-Benz C230 Cabin Air Filter
How many layers does the 2003 Mercedes-Benz C230 Cabin Air Filter contain?
The 2003 Mercedes-Benz C230 Cabin Air Filter contains 3/5layers:The 3 layers model contains: - Non-woven pre-filter layer - Non-woven cover layer - Microfiber layer
The 5 layers model contains: - Non-woven pre-filter layer - Non-woven cover layer - Microfiber layer - Activated charcoal layers
Radio code fro 1998 mercedes c230
my 1998 Mercedes remote, stop working. I've changed the batteries in the remote and changed the car battery.. but my car still will not engage the key to start.. what do i do??
Jan 26, 2011 | 1998 Mercedes-Benz M-Class
Mercedes-Benz 2012 Mercedes S550 Quarter Window Regulator 3t93400o 230 Type; SL550 and SL63, Driver Side Atlanta, Georgia Logo
77 people viewed this question
Top Mercedes-Benz Home Experts
john h
Tom Chichester
Are you a Mercedes-Benz Home Expert? Answer questions, earn points and help others
