Question about HP Photosmart 6520 e-All-in-One - multifunction printer / copier / scanne
Lower photo tray and gears sound like they r grinding
Only works if u hold the tray in hard by hand
    Champion:
  • 220 Answers
Sound like the tray holder broke. if it doesnt cost a lot try replacing it or sometimes it is better to replace the whole printer.
Posted on Jan 04, 2015
Why does my 2003 S Type Jaguar shifts hard in lower gears?
You're probably shifting wrong. Or there's a problem with your gear ratio or clutch. are you grinding the gears or is it just shifting weird?
Sep 14, 2014 | 2003 Jaguar S-Type
Grinding sound on start up, you can move the carrier with the light down to 1/2 way(by hand, power off) turn on power, carrier will return to start position and get a grinding sound (lock have been taken...
First of all, the grinding you are hearing is the gearing and possibly the belt fouling. This could be due to a problem with the motor which drives the gears that actuate the belt pulley. If you choose to dismantle the unit, test the motor without it being under any load (ie connected to the drive pulley), grinding at that point will point to the motor, inspect the gearing, look for chipped or broken cogs and see that the gears mesh ok. See f any shims or C clips have fallen off the spindle ends and refix. Remember to regrease the nylon gear bushes with white grease as you re-assemble.
Aug 02, 2011 | Epson Perfection 4490 Office Flatbed...
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
Grind when putting into reverse, hard to gp into 1st gear
When it is hard to go into gear or grinding when going into gear is an indication of worn synchronizers. The only solution is to take it to a mechanic that specializes in transmissions and having the synchronizers replaced. Sometimes a weak clutch and clutch plate can make it hard to go into the lower gears, you may want to examine these first.
Aug 06, 2010 | 1995 Chevrolet C1500
2003 Nissan Sentra SE-R Spec-V clutch sticking and hard shifting
I am dealing with a very similar issue on my 03 Spec V , So far i noticed the clevis pin was loose and the locking hitch pin that slips thru it had fallen out . this caused the gears to not wanna engage due to the bolt behind the clevis which runs to the master cylinder was not getting pressed in when i pushed the clutch pedal in because the clevis pin was slippin on n off giving me no pressure up top .. I had to remove my lower dash panel in order to get visual n hand access to this pin , it is a tight spot to work in as well . May be easist to remove the 4 14mm bolts that hold yur driver seat in to give ya more room to work n stretch out ur arms
Sep 19, 2009 | 2003 Nissan Sentra
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Canon SD600 Lens error
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon IXUS V2 Digital Camera
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
HP Photosmart 6520 e-All-in-One - multifunction printer / copier / scanne Logo
103 people viewed this question
Seeker5211
Seeker5211
