Question about Janome Sewing Machines
Why won,t my memory craft 4000 sew on straight stich setting it will sew a straight stich only on zigzag
Cleaning changing needle cotton settings
  • Janome Master
  • 1,860 Answers
Sounds like the machine needs a adjustment, it would be a good idea to have the machine checked
Posted on Dec 09, 2014
When sewing after 5 mm the top color cotton is building under the material and stops.I opened it up clean the dust and still the same. can some one give me a hint please . thanks."?"
Remove the upper thread completely. Install a brand new needle. RAISE the presser foot and rethread from the beginning. Confirm with the owner's manual the threading pathway is correct. Set the upper tension to the midway point between the high & low number. Retest.
Correct tension is when the upper and bobbin threads meet in the middle of the fabric. If bobbin thread is showing on the top of the fabric, loosen the upper tension. If upper thread is showing under the fabric, tighten the upper tension.
Make sure the thread, needle, and fabric are compatible.
All About Needles
Mar 06, 2016 | Janome Memory Craft 4000 Sewing Machine
How can I. Get a manual for a memory craft 4000?
Try this web site.
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
May 09, 2015 | Janome Memory Craft 4000 Sewing Machine
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Riccar 555su I'm having a problem with the zig zag function. Straight stich is fine
Are you using the recommended settings in the owners manual?
Apr 18, 2014 | Sewing Machines
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
What type of needle does a Memory Craft 4000 take? we need to replace the sewing needle.
the needle is the kind which is flat at the back, the round ones being for overlockers. my manual for the 9000 says #11- 16
Sep 13, 2010 | Janome Memory Craft 4000 Sewing Machine
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
64 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
