I have a QR2000 home theater system. And the problem is I have audio but no video how can I fix this issue plez thx in advc
5 Suggested Answers
smeago1
  • 136 Answers
SOURCE: Does not play multichannel audio (5.1) input through optical digital audio
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
smeags.
Posted on Jan 07, 2008
SOURCE: LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Posted on Jun 19, 2008
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Philips hts 3265
hi,lg lh d6230a home theater player display show the dvd error but not opening cd room .why this wrong please help me.send me reply
Jan 15, 2014 | Audio Players & Recorders
Tip
How to fix a logitech surround sound system
if there is no light on the control, check the mains fuse on the back of the woofer box, if blown, you may have an amplifier ic (tda7294) blown (there are 6 on the big board), replace the ic, if still no sound, mute may be blocked in on position, on small side board there is a transistor (2n4401) connected to a white wire going to the big board, replace the transistor (you may use a bc337)
on Nov 02, 2014 | Logitech Z-5500 Surround Sound Computer...
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
I have a RCA Home Theater System RT2380BK I have the speakers wired but i want to hook it up to my dish network when I'm watching movies.Can u help me?
The dish network reciever should have audio and video out on the back, If its a HD device it should also have COAX out (hd audio) get the cables for audio and feed the into a input on the back of your home theater system, there should be several inputs, usually labled like video 1 video 2, tape deck etc etc. the audio in are red and white or red and black usually, the coax connector is orange, and you only need one cable to hook that up. If you have HD audio on the dish network that will sound best in your home theatere system
Mar 10, 2011 | RCA RT2380 Home Theatre System System
LOST MANUAL HOW O YOU HOOK UP THE SURROUND SOUND TO TV
1. Does your TV has an Audio OUT? If it does then connect the TV audio out to your Home Theater system's Audio In.
2. Are you using Cable box? If you do then connect the Audio out of your Cable box to the Audio In of your Home Theater system. video out of your cable box to the video in of your TV.
Jun 25, 2010 | Philips Magnavox MRD500VR System
Hooked up home theater system, sound but no picture
are the red and white for "audio in" to the theater system receiver and the yellow cable hooked up to "video out" on the receiver and "video in" on the tv?
Typically most theater systems do not have "audio out" connections because they produce the audio. The receiver will have several "video out" connections, one of which needs to go to the tv.
Mar 12, 2010 | Audio Players & Recorders
I can capture video into FINAL CUT from VHS deck via ADVC-300, but there is no audio. Is this common?
it should not be. Are you getting audio signal levels on the ADVC-300? I think it may be a connection problem. I always get audio from vhs, even through a camera or hdv deck. Never mind a converter box.
May 21, 2009 | Canopus ADVC-300 A/D Converter Video...
Problems tuning radio stations from Memory 1
  1. RCA RT2360 Home Theatre in a Box Consumer Electronics Discussions on Home Theater Audio Video including DVD MP3 HDTV ... I thought the new RCA RT2360 receiver took care of audio and video. ...
    forum.ecoustics.com/bbs/messages/3/9749.html - 18k - Cached - Similar pages -
  2. RCA RT2360 review - Home Theater Systems Television: 32-inch RCA TV Entertainment series ... Sound system: RCA Home Theater Audio/Visual Receiver RT2360 with built-in Dolby . ...
    www.retrevo.com/s/RCA-RT2360-Home-Theater-Systems-review-manual/id/402ag601/t/1-2/ - 66k - Cached - Similar pages -
  3. Features and specs on RCA RT2360 Theater System - Home Theater ... RCA RT2360 Theater System product features and complete specifications. ... product reviews and stores ratings on RCA RT2360 and other RCA Home Theater Systems. ... reproduction of the original multi-track layers of audio sound. ...
    www.shopping.com/xPF-RCA-RCA-RS2642-NEO-5-BOOKSHELF-SYSTEM-22342661 - 37k - Cached - Similar page
You have removed results from this search. Hide themLoading...
Mar 27, 2009 | RCA Audio Players & Recorders
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
87 people viewed this question
 Grubhead
Grubhead
