Question about Garden
How do I replace the clutch? - Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
On what make and model? you probably just have a stretched belt
Posted on Jan 05, 2015
Is there a place to add transmission fluid to a 2002 kia sport age clutch, mine is slipping
no transmission fluid in a clutch system
only brake fluid
and that is in the reservoir at the top of the clutch master cylinder or shared with the brake master cylinder
if the clutch is slipping it indicates the need to replace the clutch master cylinder or tor replace the clutch assembly
Clutch master cylinder is cheaper and easier and is generally the main reason for slipping clutches unless you have a cable clutch in which case replace the cable
May 27, 2017 | Kia Cars & Trucks
Clutch and engine check light plus clutch got eaten up in 2 weeks time
If ur have replace ur clutch but the check light still on it mean your CO sensors need to clean or replace.
Jun 17, 2016 | Nissan Cars & Trucks
Hyundai. Tucson, 59 plate' clutch slips at high speed when changing gear
check /replace clutch cable or replace master cylinder. If the clutch has not been replaced it may need a clutch kit as the indications are that the pressure plate is weak ( worn clutch plate or from overheated clutch)
Feb 10, 2015 | Hyundai Tucson Cars & Trucks
How can i fix the squeak on the clutch on 2007 crv
Most likely the it is a worn clutch. Replace it as soon as possible before the metal parts start to wear out which can be expensive to fix. All manual cars needs clutch replacement at some point.
Sep 05, 2014 | Honda CRV Cars & Trucks
Clutch stick gets stuck and I can't change gears
It can be due to the:
- Engine rpm high.
- Brake oil level too low.
- Brake oil contaminated.
- Air in the clutch system. (Bleed air)
- Worn out master cylinder clutch, upper. (Replace)
- Worn out clutch cylinder clutch, lower. (Replace).
- Worn out clutch plate. (Replace)
- Worn out pressure plate. (Replace).
- Clutch bearing defective or seized. (Replace).
Aug 30, 2013 | 1999 Toyota Corolla
How Do You Replace Clutch Master cylinder
honda civic.... replaced with new clutch and clutch kit... now i have to replace the clutch master cylinder..... only done 167k since new clutch.... should this have been checked when the clutch was replaced?
Jan 11, 2011 | 1998 Chevrolet Camaro
Replaced master and slave clutch cylinders but
if you replace and shure to make a good bleed on clutch fluid, then replace clutch disc
Jul 27, 2010 | 1991 Toyota 4Runner
Chevy l989 4X4 5 speed manual clutch not working
Almost every time a clutch is replaced in a GM with hydraulic release system that system is replaced as well. You can try, and try, and try again to bleed it, but you will eventually replace the clutch slave and master cylinders. Once the slave is allowed to fully extend, it is then virtually impossible to make it function correctly again.
Jul 08, 2009 | 1998 Volkswagen Passat
Clutch fried on 2007 Hyundai Tuscon
Yes they are related. I had the same thing happened to me the forks got bend so I had to replace the whole clutch system, clutch cover where the forks are at and the clutch itself. When they replace the clutch plate they should also replace the clutch cover or vice versa. I don't think it's you it's probably just the car. I suggest you have the clutch plate and clutch cover replaced.
Jan 21, 2009 | 2005 Hyundai Tucson
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
