Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Oil coming out of mixer above bowl
Have oil coming out of the mixer just about the bowl area were the beater goes in. I taightened the two black slottle screws on the side and when I tipped the mixer backwards oil run out and down the back of the stand behine the bowl. Can this seal be replaced if is broken?
  • Anonymous Mar 25, 2008
    hello, i have a K45SS and i went to use it and i notice it was leaking some black oil slowly and hopefully i got down with what i was mixing, but i hope no oil got in the stuff i was mixing. it was leaking above the mixing bowl slowly leaking. why is it leaking, is there a O-ring or something?
  • diane1319 Dec 03, 2008
    I have a model K45SSSWH and it is leaking oil also. My daughter has the same problem. What can we do? Is it ok to use or not?
    Problem Solver:
  • 10 Answers
Don't open up the "works" part of your mixer if it is still under warranty!!!! If the policy hasn't changed, you'll void the warranty by doing that.
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site. Tell them "mnme" sent you. (LOL)
http://www.kitchenaidconversations.com/
Posted on Feb 09, 2008
A standard maintenance procedure for these KitchenAid stand mixers requires periodically changes the grease in the gear housing. After several years and/or hard use, the grease eventually breaks down and becomes thin, like oil. The chrome ring above where the beater attaches is actually a "drip cup" and is designed to catch the oil, but eventually it overflows. The unit will need to be opened up and the old grease removed and replaced with a special high temperature grease recommended by KitchenAid (Part No. 4176597) Essentially, it is a high temperature type of grease that will resist breakdown for longer periods than standard bearing grease used for cars. It is a very common procedure and can be performed by a handy homeowner or a service center. To do it yourself will take about two hours and instructions can be found at several locations online. Once done, it will purr like new and last several more years.
Posted on Dec 09, 2007
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Wobbling on inside of mixer when beater is rotating
If the beaters are hitting the bottom of the bowl, try adjusting the upper-head stop-screw located near the top of the lower stand--it determines how far the head drops down and therefore, the height of the beaters above the bowl bottom. Hope this helps!
Dec 27, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
Mar 28, 2010 | KitchenAid RRK150 Stand Mixer
My KitchenAid Professional 6 mixer has been used about 2 years. Lately it leaves a black trail in my icing/batter/whatever from the finish being worn off the metal beater--the triangular one. The bowl has...
It sounds like you have two problems. First, the black marks are usually because of a reaction between the beater and certain chemicals used in dishwashers. Try washing the beater by hand and scrubbing it throughly to remove any residue. If this works, don't use the dishwasher again. You could also buy a plastic coated beater.
It also sounds like the bowl height needs adjusting. There is a screw just under the head for this.
Jan 08, 2010 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid model KB26G1XGN. The planetary gear appears to be falling out. The mixer blades were hitting the bowl before I had the bowl in the locked position. I got the top of the gear box off but can't...
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
See second comment...
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 12, 2009 | Food Mixers
Bowl too low
Hi, JAKELEGJEETE, You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 11, 2009 | Food Mixers
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Bowl-Lift models
• Unplug mixer.
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Beater rubbing bottom of bowl
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
May 29, 2008 | Black & Decker MX55 PowerPro Hand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
308 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
