Question about Samsung UN32EH5300 32IN 1080P WI FI LED SMARTTV REFURBISHED 30 to 39 in
My Samsung TV stopped recognizing my mac. I have 2 mac airbooks and it doesn't recognize any of them. I'm using an HDMI cable. It worked fine till 2 days ago and nothing had changed.
I've tried reseting the TV\the mac, tried with a different mac, tried a different HDMI socket. None worked....
  • 39 Answers
Call Samsung , they can send a signal to it to reset the internals , also can give you an idea what might fix it .
Posted on Dec 13, 2014
SOURCE: help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Posted on Dec 31, 2008
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
  • 325 Answers
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
Got sound, but no picture & cannot get into setting, help
You can try using the RCA connections as it sounds as if hdmi is switched off.this will be the yellow plug into a scart socket adapter.
if you are still having connection issues try a different hdmi cable and or reset the box using a paperclip near to USB sockets.
Apr 06, 2015 | FocalPrice MX Google Android 4.2 Dual-Core...
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Imac to jvc
Hi. A couple of things to try.
Switch everything off. Make sure your connections are sound then switch on the TV. Then switch on the mac. With luck the system should sort itself out. However, I have heard of others who have had nothing but grief trying to get similar arrangements to work.Normally ther Mac does it's own thinking, works out what is at the other end and puts up the display without any problems - other than the picture width being invariably wrong until you find the correct size.
There are no drivers to download - the issue is generally that the TV is not reporting back to the computer the correct resolution and scan rates.
You may have to dive deeper into the TV's menus to locate the means of altering the parameters.
Jan 07, 2012 | Apple iMac Desktop
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Westinghouse 1080P 42" LCD TV - HDMI stopped working
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
PS3 vs Toshiba 65" 65hm117
Sorry to here about your problem. I have a 65HM167 Toshiba tv which is the same as your model, and I have my PS3 connected HDMI with no problems. Try using a different brand HDMI cable and a different HDMI input on the tv if you have not already done so. Hope this does it for you, good luck.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Samsung UN32EH5300 32IN 1080P WI FI LED SMARTTV REFURBISHED 30 to 39 in Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
