CONMED SYSTEM 2450 problems code is 160, what is the meaning? If a service manual is better, thank you for your help!
The machine can not be normal self detection, error code display is 160, do not know which place is a problem, you know?
SOURCE: frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Posted on Jul 13, 2008
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Posted on Dec 01, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
SOURCE: Please I have got error
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Posted on Feb 11, 2011
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Posted on Nov 20, 2011
Can you tell me how to find the service manual for the Conmed Pro 6200M or 6350M?
I see so many search results I can look all the way through the documation.
http://www.conmed.com/search_test.php?zoom_query=Conmed+Pro+6200M+manual&image.x=16&image.y=6
Terry
Oct 16, 2013 | Computers & Internet
I have a Toshiba satellite 2450-401. I have recovery CDs. but the CD drive is not working. What is the procedure to recover my system?
pxe means it's trying to network boot. you need to go into your bios settings and change your boot up priority to cd first
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jun 25, 2012 | Toshiba Satellite 2450-401 Notebook
Conmed sabre 180 code eroor hlp3 whAT MEANS ?
hello friend the error response 3 is recalibrate all system parameters. the resistance you have to have on hand are 10 ohms and 150 to first calibrate 1/2w begins receiver plate and then bipolar line.
May 18, 2012 | Office Equipment & Supplies
I can't use my nokia c3-00 with Rm-614 in Nigeria sent to me by my brother from uk usig vodafone network.The IMEI No. 355966041581037. please help with a free unlock code for this device. thanks
Hi..
Getting free unlock code is not possible. So better try to get code from any trusted service. Contact your network carrier and ask for code, or if you wish to get code from any online service means i would suggest you the service provider Theunlockspot.com to get perfect code for your device. It'll be helpful and check it out..
Dec 03, 2011 | Cell Phones
I need a service manual-type electrosurgical unit brand Conmed Sabre 180
i need what is the means of the HLP1 and HLP 4 on the error code...
Dec 04, 2010 | Health & Beauty
How do I clean the underside of the glass on the 2450 epson perfection scanner?
Scanners are not meant to be user serviceable. This means that to clean the inside of the scanner, its better that it be brought to the manufacturer who can do this in a safe and correct manner. Believe me, it is worth doing this than ending up having a non-working scanner.
Jan 11, 2010 | Epson Perfection 2450 Photo Flatbed...
I have full gas in my car but still no cold air inside the car
If you over charged the system your a/c will not work. To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105PSI  Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25PSI  Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better!  Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged.
If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
Good luck and hope this helps, keep me posted be glad to answer any question you may have.
Jul 02, 2009 | 1998 Honda Prelude
How do I service my A/C 2000 Chevy Impala LS
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI Normal high side reading ranges from 200-350 PSI
If you are going to by the recharge kit at an Auto Parts store, With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Good luck and keep me posted, be glad to answer more questions you may have.
Jul 02, 2009 | 2000 Chevrolet Impala
The a/c on my 2006 honda pilot is not owrking and appears to have a low refrigerant charge. I want to recharge it and find the leak with die. what is the amount of 134a to be fully charged
Adding freon or topping off a cars A/C system is the most common task performed to restore performance and get cold air blowing again. However, adding refrigerant isn’t always the solution for car air conditioning problems. There can be many other things wrong besides a system being low on refrigerant. To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
*Make sure the condenser fan comes on when the readings are being checked.
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the R143a and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Hope this helps. Keep me posted, be glad to help get you cooled again.
Jul 01, 2009 | 2004 Honda Pilot
How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
Aug 16, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
