Question about Bobcat Equipment Skid Steer Flatbed Tractor Trailer
The 19 second preheat count down won't work on my s 205 bobcat goes directly too the hour meter only can anyone help
    Master:
  • 706 Answers
Bobcat.com is official web-site, they have support page. Also, local equipment dealer is good source for assistance
Posted on Dec 07, 2014
Just bought a used 2007 bobcat 430zhs mini excavator. Seller did ma a favor and pressure washed it. Now the hour meter flickers and only top or bottom of the lcd operates. Can't read codes or hours
It might dry out, if not you will need to replace the meter. If you shine a light into the meter you should be able to get the hour reading and when you order the replacement you can have it set to the correct hours.
Feb 16, 2017 | Mini Cars & Trucks
My oven takes 35 minutes to preheat to 350 and keeps fliping between bake and preheat. Temp goes up and down.
Sounds like your ignitor is becoming weak, Just because it glows doesn't mean its strong enough to work correctly. If you have a meter, check for amperage (round 2.2 - 2.6, Flat 3.2 - 3.6) to be good. If you don't have a meter, replace the ignitor first is what I would do. Good Luck
Apr 20, 2016 | Kitchen Ranges
Bobcat t190 problems
Possible capacitor if screen flickers in any such way.
(sorry I'm not much help with this one)
If replaced, will need programming and hours entered.
If not replaced. sounds like its bios or startup is affected by either a loose wire, sensor of some sort, loose ignition, or capacitor inside has a rounded top (crowned)
May 23, 2013 | Garden
I bought a new home and there is no manuals and it is stuck on the setting sabb the stove top works perfect but the oven only heats to 260 on this particular setting??
Try this:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Hope it helps!
Jul 27, 2011 | KitchenAid KERC607 Electric Kitchen Range
We lost the manual and can't find the hours of usage on the miller 250 bobcat serial #LH005560.Where would we find it on the machine?
Hour Meter: With engine off, place Engine
Control switch in Run/Idle position to view engine
hours. Meter is located on the front panel in the top right corner.
For more help see page 23 of this document:
http://www.millerwelds.com/om/o4419m_mil.pdf
May 09, 2011 | Computers & Internet
Operating manual for bw 30 & bg 30 timer counter
1) Identify product on following page:
http://www.hugo-mueller.de/elapsed-time-counters/mueller-bw-30-bg-30,p,en,8,34.html
2) Sales sheet shows model numbers and voltages and shows that product is hour meter:
BW30 is AC alternating current with choices 230Vac 115Vac or 24Vac
BG30 is DC direct current 12-48VDC
http://www.hugo-mueller.de/download/34_DB_BW30_BG30_BW22_GB.pdf
3) Hour meters normally have 2 terminals, but there is not a photograph of back of product.
Hoping you will photograph your product and post image on your website and add a comment to this thread with web address of image, along with other information you have.
4) Usual set up for timers and counters: terminal 1 is for black wire L or L1, and terminal 2 is for white wire N or L2.
If terminals are not labeled, then wires can be connected either way, but as you face terminals, terminal 1 is on left.
5) Wiring:
Hour meters are wired in parallel, not series.
For example hour meter on 240V pump: 2 wires go to pump.
Simply connect each hour meter terminal to one of the wires.
Another way to illustrate: If you test electricity using two-prong tester, you touch each tester lead to one of the wires. Hour meter connects same way.
6) How hour meters work:
Hour meters count number of hours electricity is turned on.
For example I have 240V Grasslin hour meter connected to water well pump.
Water well has pressure switch that turns pump on-off.
If hour meter is connected before pressure switch, then meter simply runs continually since it receives power all the time.
So hour meter has to be connected after the pressure switch. And then meter counts only when power is turned on to well pump. This way I see how many hours my pump runs and then estimate pump cost by multiplying hours x pump wattage.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Miller Electric Manufacturing Miller...
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
ARROW pad.
"3".
shut-off.
Thanks for using Fixya, let me know.
Jan 06, 2011 | Maytag Ovens
How can I get a meter reading for an e-studio 160 copier?
In order to get a meter count, turn the machine completely off (including main power,) and press and hold "0" and "8" simultaneously, then power on the machine. After about 5-8 seconds of holding these keys, the machine will boot into test/service mode, and at that point you want to type "257" and "start," then the meter count will be displayed.
-David.
Nov 03, 2010 | Toshiba e-Studio 205 Copier
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
Bobcat Equipment  Skid Steer Flatbed Tractor Trailer Logo
585 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
