Question about Tascam FW 1884 FireWire Audio/MIDI Interface & DAW Control Surface
I need a reasonably priced audio interface to use with a remote synth and a MacBook (Garage Band). Any ideas?
I need advice on a good, reasonably priced audio interface to connect my midi keyboard to my MacBook's Garage Band program.
  • 20 Answers
I would go for getting someone else to record at studio, means they have all the professional ideas to bring to the table, solve problems, but if your just playing around in home a small focusrite 2/2 should do you, with 2 inputs for left and right mono from desk, or also dual linking in two separate channels via xlr.
Posted on Dec 23, 2014
I have a used synth, and want to use it as a controller keyboard for GarageBand and other programs.
https://www.google.co.uk/search?espv=2&q=macintosh+MIDI+interface&spell=1&sa=X&ei=BKrLVOGMHpKBabLCgfgN&ved=0CBwQvwUoAA&biw=1920&bih=971
Dec 09, 2014 | Music
Can a Korg CX3 Organ 61 keys be compatible with the RolandFantom XR module?
Hi, from what I can tell you cound plug your CX3 into the synth module with a 1/4 inch patch cable and run the audio through it, however I think you will be quite limited in what you can do to modify your sound.
Where the synth really works well is when you feed it digital input data. For you to be able to do that your CX3 would need midi outputs and while I don't have one, I looked it up and can see that the CX3 is too old and does not have midi capability.
Midi (musical instrument digital interface) is a common language that allows musical devices such as your fantom to communicate with other devices. A keyboard with midi running into a synth is in essence just a control surface, a way for you to input data into your synth module, it is making no sound itself, but rather outputting digital data into your synth which in turn generates the sounds you want it to. There are allot of keyboards out there that are only for this purpose and are simply controllers. For example, M-Audio Oxygen 61 - 61-Key USB MIDI Controller. I'm afraid your CX3 is just too old to be able to do this, however, I imagine some of the sounds that thing makes are very vintage and good, and modern synthesizers often times just cant reproduce that (though they are getting batter all the time). Hope that helps :)
Dec 20, 2013 | Music
No output signal for vocalist live 3
If the mic is a low Z- mic, that might be the issue. Check the mic straight into the sound card of the mac and see if it works or if it is shorted. Is there a switchon the mic? it may be dirty.
Jan 28, 2012 | Music
What's your problem?I have a behringer UMX490 plugged by UBS into my pc . Do I need a specific sound device plugged into the MIDI output or will it play though my computer
Your UMX490 is already provided with an audio interface working via USB
Just hook it up to your computer and you will be able to play the built in sounds.
The MIDI output is for allowing you to control external samplers, synths and other equipments.
Regards
Sep 29, 2011 | Music
What exactly do I need to connect a Mackie 402-VLZ3 to a Macbook Pro ? Where can I buy the cables? Thanks!
The internal audio systems in the PC's are inadequate for high quality work. You should get an external audio system that attaches via firewire or USB to your MAC. Then use balanced cables from the mixer to this audio interface. There are MANY different audio interfaces... Search the music equipment suppliers in the "recording" section of their catalog...
Feb 10, 2011 | Mackie 1202vlz3 12 Channel Mixer
What cable would I need to connect the audio output of a Yamaha Claviola to a Mac running Garage Band?
in order to make a good connection with digital audio i recommend using an audio interface i personally use a maya44 usb.
Feb 08, 2011 | Yamaha Music
I can´t find CASIO CTK-810
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
Jan 04, 2011 | Casio CTK810 61 Key Keyboard
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
Feb 09, 2010 | Casio CTK810 61 Key Keyboard
Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Aug 07, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Tascam FW 1884 FireWire Audio/MIDI Interface & DAW Control Surface Logo
54 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
