Flashing lights
1. Switch off the printer (the button Power
2. Holding button Resume , include the printer (press the button Power
3. Holding button Power , release the button Resume (the indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press the button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (the indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press else raz.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times podryad.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6 :
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press else raz.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant sb
