Question about Singer 5532 32-Stitch Heavy Duty Sewing Machine
I have a singer 5532. Sewed fine until today. Now it will not sew with the needle in the left position and none of the decorative stitches. (zig zag) work
Cleaning bobbin area, and checking for lint or thread in top of the machine. Changed needles, thread, bobbin.
  • Singer Master
  • 1,860 Answers
It's possible that the machine may need a adjustment, or could have a broken part.
Posted on Dec 08, 2014
5 Suggested Answers
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
SOURCE: I am having trouble getting my singer 6199 sewing machine to sew. The top thread will not pick up bot thread. I tried changing needle, changing bobbin, rewinding bobbin, rethreading machine & bobb
did you get the needle in correctly--all the way up into the needle holder
& the flat side of the needle goes to the back of the machine
also after you check the needle & it's in correctly it's very possible that the machine is out of time & a sewing machine repair technican would have to retime the machine
Posted on Mar 01, 2012
SOURCE: singer 7469 will not zigzag
it's possible that a gear or inside cam could be worn or broke, the machine needs to be serviced
Posted on Mar 09, 2012
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Singer 756 zigzag timing is off
The machine may be slightly out of time so it works in straight stitch but not zig-zag.
Oct 23, 2017 | Singer Sewing Machines
Needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
Dec 09, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Singer 5532 32-Stitch Heavy Duty Sewing Machine Logo
108 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
