Question about Lands Phones
How do I get my speaking caller id on my Vivitar phone to work, what are the instructions
It has 3 button speed dial, date time, multipe languages, speakerphonelarge buttons
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
  • 65 Answers
SOURCE: Time and Date wrong on caller ID
I would check with your service provider. It maybe just a programming error in the switch from there.
Posted on Feb 02, 2008
SOURCE: Caller ID does not work
I FIXED IT!!!  YIPEEE!!
What I did was UNPLUG the base's power unit from the wall... waiting about one minute, and plugged it back in.  That caused it to "reboot" the entire system, and the CID now shows itself.
Posted on Mar 07, 2008
  • 4 Answers
SOURCE: instruction manual needed
I have uploaded the manual for all to view
Innovage manual
Posted on Jun 20, 2008
expertsarah
  • 70 Answers
SOURCE: caller id button is not working
try to change the battries of your phone.
Posted on Jun 18, 2009
How do I change the setttings in my phone to ring more times before it goes to voicemail?
look it over many have a button that slides to change that or look thru the setup menu.or manual
Jan 26, 2016 | RCA ViSYS 25423RE1 4-Line Telephone, Blue...
Southern Telecom Large Display Caller ID CID 50LD manual
Set Date and time manually if desired. 1. Press and hold the [dial] button until the display show "SET left OR right ". 2. Use the up or down buttons and select "DATE/TIME" andpress the [dial] button to enter.3. Use the up or down buttons to set the hour, minute, AM/PM,month, and day.4. Press the [dial] button to confirm your selections
Nov 28, 2013 | Southern Telecom Large Display Caller ID...
Pulse
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Nov 08, 2012 | Emerson EMSEM2646WH Phone
The caller ID screen is so faint I can't read it. Is there a way to brighten it or change the contrast so I can read it?
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
and set.
Oct 16, 2012 | Emerson EM2646-WH Big Button Corded Phone...
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
http://www.retrevo.com/d/df/MANUAL000032975.pdf?doc=532906c5a747ab87134404141e9c11c8&ts=1313184836863&rk=0.17208479428095913
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
GETTING STARTED
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
E=ENGLISH
F=FRENCH
S=SPANISH
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Joe.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
You say you cannot get to the menu from the mute/ok button?
What happens instead?
FROM DA BOOOK looks pretty clear to me.
Handset Setup
1. Make sure your phone is OFF (not in TALK mode).
2. Press the mute/menu OK button to go to the main menu.
3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
Language
From the Handset Setup Menu:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
Apr 29, 2009 | Uniden Cordless Phone
Emerson EM2515
The phone actually has a "OPTIONS MENU" where you can set the date. When the display is showing time and date, press the "DIAL" button first and then while still holding down the "DIAL" button, press the "DEL" button the "Options Menu" will appear after about three seconds of holding down both buttons. Use the "REVIEW" arrow buttons to scroll through the menu and the "DIAL" button to select the options.
Jun 09, 2008 | Emerson Corded Phone
Durabrand phone model 5562 .
press and hold the delete button and press the up and down button to set lcd contrast, language, home area code, set time/date.
Feb 27, 2008 | Lands Phones
How to proram speed dial
Here is the solution:
1) Pick up the handset
2) Press the "Store" button
3) Dial the number that you want to store
4) Press the "Store" button
5) Press one of the Memory button such as M1, M2, etc.
6) hang up the phone (put the handset back to the base)
When you're ready to dial the number, just pick up the handset and press one of the Memory button that you just use to store your desired number.
Best of luck,
KP
Dec 18, 2007 | Sakar Talking Caller-ID Speaker Phone
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
