Unplugging
Hello Brad;
My name is Peter. I am a retired field service appliance technician.
There are several reasons your unit will not start.
1.) Air flow problem.
Poor air flow will keep your unit from starting. If you have had to run your clothes through the dryer twice to get them to dry, then your unit is plugged up with lint. With this model you have to pretty much disassemble the unit to clean. Two screws on the back of the top cover hold the cover on. Remove these screws and pull the top cover back about 1/2" and lift.
2.) Thermostat.
This component is mounted on the side of your heater box assembly. You need to remove this and with a multi-meter set to the lowest Ohms, if the Ohms reading is anything other than '0', them the thermostat is bad.
PART NUMBER: DC96-00887A - Cost: $11.00
PART NUMBER: DC47-00015A - Cost: $9.00
I do not know witch thermostat you have in your unit.
3.) Apush the start button and the dryer won't start. P - 25310837-hvg3snwqvesmyyt5sfu3t0jd-5-8.jpg"/uploads/images/25310837-hvg3snwqvesmyyt5sfu3t0jd-5-8.jpg" alt="25310837-hvg3snwqvesmyyt5sfu3t0jd-5-8.jpg" class="h_mi" />
PART NUMBER: DC47-00018A - Cost: $21.00
4.) Micro Switch - Located on motor drive pulley.
push the start button and the dryer won't start. P - 25310837-hvg3snwqvesmyyt5sfu3t0jd-5-15.jpgholding the switch button in.
PART NUMBER: 3405-001077 - Cost: $7.00
5.)push the start button and the dryer won't start. P - 25310837-hvg3snwqvesmyyt5sfu3t0jd-5-24.jpg the end of your blower wheel housing.
Also, you can Ohm this out. Should read '0'.
PART NUMBER: DC32-00007A - Cost: $8.00
6.) Door Switch.
This too can be ohm out, should read '0'
PART NUMBER: DC64-00828A - Cost: $17.00
I am glad it is not your control panel, which is no longer available.
SOURCE: have a retangle showing as the dryer ends it dry
I have the same problem with my dryer. I noticed this rectangle that showed up on time dry and there wasn't any code that matched this in the manual. I called samsung and they told me to flip the breaker and see if that helps. I have not tried another load, but I hope that fixed it.
SOURCE: When I push the start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
SOURCE: Panel powers up, no codes, but the drum will not
Hello Jim,
I'm glad I was able to help you. Hopefully you can return the help regarding my assitance on the chat session for your dryer.
For some reason your accepting my solution has not been recorded although you rated the help as 4 thumbs up...my account shows the solution was rejected.
Perhaps you can log in again and amend the error, as much as I like to help with the chat sessions, it is based on customers honoring the system and us experts providing help on the premise of getting paid.
Thank you.
Regards,
Macmarkus :)
Testimonial: "Very fast and professional help. Had a handle on the problem right away & gave me the solution. Sent me to a site to view how to fix it! Great!"
SOURCE: I have a Samsung DV350 AG gas dryer, push start
can you hear motor running,if not maybee a sensor,something with door switch?
