Question about Amana Refrigerators
Determine if the ice maker is not working
Ice maker arm in correct position
  • Amana Master
  • 5,323 Answers
ICE MAKER not making ice:
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Posted on Apr 17, 2015
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
  • 25 Answers
SOURCE: Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Posted on Feb 10, 2008
rickzilla
  • 706 Answers
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Posted on Sep 15, 2008
SOURCE: Ice maker grinding sound
I had the same and found the same solution. Chances are the problem will come back. Just over a week ago (when it was freezing cold in Florida) I took everything out of the fridge and freezer, unplugged it, even pointed a hair dryer in the ice unit. Once I was done it was completely defrosted and dry. I have not heard anything since - and I can sleep again ;-).
Posted on Nov 05, 2008
daddyo742001
  • 70 Answers
SOURCE: ice maker won't work
Temp needs to be down to 0 or below for ice maker to activate. once that happend arms that push ice out will go around and made switch in end of ice maker that turns on water selenoid valve that adds water. this could also be electronic switch. main thing is its cold enough to activate. If it don't work then Ice maker may be bad or no power getting to it. turn freezer as cold as you can may mean setting refrig side warmer. If it has coil under refrig clean it out. Air around frig should be 68 - 75 degrees if poss.
Posted on Jun 29, 2009
GE Side-by-side PSSB6KSXCCSS paddle stuck in off position on ice maker. Spring is in correct holes but paddle does not move
Your ice maker will move the arm if working properly. I bet the ice maker is dead and the ice forks are stopped in a position other than the home position
Ice Maker Assembly WR30X10093
APPLIANCE 911
Sep 18, 2016 | GE Refrigerators
LG LRSC 26920tt won't make ice
In order to determine the problem you must check a few things:
1) Is there water in the ice tray? If not. verify the saddle valve is turned on, check the connection on the water valve, verify that there are no kinks in the inlet hose, and check he water filter to see if it is clogged.
2) Is the temperature correct? Make sure the fans are working properly and air is flowing. Verify the the frig and freezer are at the correct temperature and make sure the ice maker compartment door is sealing shut.
If these things check out ok, run an ice maker test. Make sure the ejector arm and feeler arm are in their original positions before beginning. If they are not:
1. Turn off icemaker and wait 5sec.
2. Turn on icemaker.
3. Wait until feeler arm and ejector are back to original positions.
To begin the icemaker test: Press and hold the test button on the icemaker for 5 seconds. If the LED, feeler arm and or ejector does not return to to their original positions the problem is with the ice maker.
The ice maker part number for your model is 5989JA0002G
Oct 14, 2013 | LG LRSC-26922 Side by Side Refrigerator
My sub-zero 680 fill arm on the ice maker will not lower. As a result the ice maker will not come on because the arm remains in the raised position. How can I get it to lower? I've tried turning off the...
Get a new ice maker. Nothing in the ice box controls the whims of that ice maker. Only it can dictate whether or not it wants to work correct.
Jan 18, 2011 | Sub-Zero 680 / S
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Apr 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker stopped making ice. I emptied ice holding tray and since then, if will not make ice. I adjusted arm in hole correctly. Arm is down and is in correct position to make ice. Still no ice. Please...
Fill the ice maker with water. If it freezes and dumps the the water control valve on rear of the refrigerator and near floor is defective and will need replace. If the water just freezes then the ice maker thermostat is the problem, Let me know,Thanks Sea Breeze
Aug 17, 2009 | Refrigerators
Ice maker arm in freezer
On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
Jul 20, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker won't shut off when full
check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Jan 30, 2009 | GE Monogram ZDI15C Automatic Icemaker
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Dec 28, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
