Question about Lexmark Impact S305 Wireless All-in-One Printer w/Copy/Print/Scan
My printhead is still saying I have a problem. I replace the ink. I turned the machine off for 10 minutes. Clean the heads with a soft cloth. It still shows the same error message. Do I need to replac
I replaced new ink. I'm still receiving the error message. "There is a problem with the printhead. Please consult users Guide". I consult the users guide. Cleaned the heads. I am still getting error message.
    Problem Solver:
  • 49 Answers
You need to replace the print head. The ink is fine but your print head is no longer good.
Posted on Dec 07, 2014
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Error code:1203
Hi Your error is to try
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Jan 30, 2010
How much would it cost to service a C6150 All In One Photosmart printer. I think I might have a clogged head. trying to weigh repair over just buying a new one. Problem seems to be with the color...
Before servicing the printer make sure you are done with these steps...
Solution #1 Manually clean the Inks and the prinhead.
  1. Power on the printer.
  2. Open the cartridge access door.
  3. Take all out the inks on the printer.
  4. Put the inks on a flat area (to prevent leakage)
  5. Get a wet clean cloth, clean the electrical contacts of the inks one by one.
  6. Look for the blue latch of the printhead and pull it up, then take out the printhead.
  7. Clean the electrical contacts of the printhead (just like cleaning the contacts of the inks)
  8. Dried the contacts of the printhead and inks using a clean cloth.
  9. Put them all back to the printer.
  10. Close the cover.
  11. Repeat aligning and cleaning the printhead using the panel. (to access it.. press setup button on the printer or the wrench, then look for tools press ok, then look for clean printhead, after cleaning the printhead, align the printer.)
Try making some print test. If your still having problem proceed to the next step.
Solution #2 Perform a partial reset
  1. Without turning off the printer unplug the power cable at the back of the printer.
  2. While the printer is off and unplug, press the # and number 3 at the same time.
  3. Wait for 1min.
  4. Keep on pressing the # and 3, then plug the power cable back in.
  5. On the printer screen you should have a message that says "NVM" reset.
(It will dome some initialization for the printer, then after that please make some test again.)
If your still having issues w/ it theirs no way for you to resolved it. Its a printer problem and needs to be replace. Please contact HP and ask for a trade in option. 1-800-474-6836
Feb 06, 2011 | Office Equipment & Supplies
HP Deskjet D2360. How can I clean the printer
take out the ink and on a soft cloth wipe the printhead down 3 times then do a cleaning on the machine
Jul 14, 2010 | HP Deskjet D2360 InkJet Printer
I had an alert that my yellow ink cartradige was low on ink. I replace it and then got an alert that my black cartridge was low on ink. I replaced that and then got an alert that says "The printhead(s)...
First try cycling the power to reset the unit. Turn off the printer. Then unplug the power cord from both printer and the outlet. Wait at least 30 seconds then plug it back into the outlet and then the printer. Turn on the printer.
If the error persists, clean the print head contacts. With the printer on, open the top cover. Press and hold the OK button for 5 seconds; the carriage will move to the left side of the printer. Release the OK button. Wait until the carriage is idle and silent. Unplug the power cord (do not use the power button to turn off the unit). Lift the handle on the print head with the error message (all for you but do them one at a time). Pull out the printhead from its slot. With a dry, soft, lint-free cloth wipe the copper electrical contacts on the front (not the nozzles at the bottom). Repeat until all the left over ink is gone and then dry with a new, clean cloth. Use another dry, soft, lint-free cloth to clean the contacts inside the printer. Remove any lingering debris.
Plug in the power cord and press the power button. Reinstall the print head (the screen should be reading printhead missing). Make sure it is firmly in place with the contacts touching the ones in the printer and the latch is secure. Repeat the steps for the other print head. Then close the top of the printer. Print an alignment page (should be automatic).
If this doesn't work, try a new print head (HP not remanufactured). The final option is servicing the unit.
I hope this helps.
Apr 25, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Printer will not recognize the new cartridge installed.
Solution
Follow these steps in the order presented to resolve the issue.
NOTE: If error messages also display on the computer, clear the error messages after each of the following steps. You might have to delete pending print jobs from the print queue on the computer to clear the error messages.
Step one: Perform a power reset
Follow these steps to reset the product. Make sure you connect the product directly to a wall outlet and not a surge protector or power strip.
Press the Power button ( ) to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the rear of the product.
Unplug the power cord from the electrical outlet.
Wait 30 seconds.
Replug the power cord into the electrical outlet.
Reconnect the power cord to the rear of the product.
Press the Power button ( ) to turn on the product.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Step two: Clean the electrical contacts on the printhead and inside the product
The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time. Follow these steps to clean the electrical contacts on the printheads.
CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
Make sure that the product is turned on.
Open the top cover of the product.
Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
Unplug the product power cord from the electrical outlet.
NOTE: Do not turn the product off by pressing the Power button ( ). This causes the carriage to move out of reach.
Lift the printhead latch.
Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot.
Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
CAUTION: Wipe only the electrical contacts. Wiping the ink nozzles, located on the underside of the printhead, can damage the printhead.Do not touch the nozzles. Doing so permanently damages the ink nozzles, and the ink stains clothing.
Figure 3: Electrical contacts and ink nozzles
1 - Electrical contacts
2 - Ink nozzles
Wipe the electrical contacts with the swab until no ink residue remains.
Wipe the electrical contacts with a fresh cloth to dry them and remove lint.
After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
  1. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product
  2. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
  3. Plug the product power cord into the electrical outlet.
  4. Press the Power button ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
  5. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
  6. Pull the printhead latch all the way forward, and then press down to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
  7. Close the top cover of the product. The product restarts and then prints an alignment page.
Apr 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
PRINTHEADS
E:0181 means Internal printer timeout. Recommend Action to Resolved this issue
1. Remove the printheads and clean the contact points gently, using a dry, soft, lint-free cloth. Replace the printheads.
2. Remove the ink cartridges and clean the contact points gently, using a dry, soft, lint-free cloth. Replace the ink cartridges.
3. Switch the printer off.
4. Remove the power cord. Wait 10 seconds, reconnect the power cord and turn on the printer.
5. If the printer does not resume normal operations, repeat the process three times.
If the error persists, the printer may need repair
Jun 23, 2009 | HP Business Inkjet 2200 Printer
HP officejet Pro 7580 problems with streaking
Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if they are exposed to air for more than a few minutes or if the product is not used for long periods of time. Follow these steps to clean the electrical contacts on the printheads. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product and stops. Release the OK button.
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet.
    NOTE: Do not turn the product off by pressing the Power button (c01346625.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01448109.gif
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle and remove the printhead c01448110.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    1. Wipe the electrical contacts with the swab until no ink residue remains, and then wipe the electrical contacts with a fresh cloth to dry them and remove lint.
    2. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
    3. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01448112.gif
    4. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
    5. Plug the product power cord into the electrical outlet.
    6. Press the Power button (c01346625.gif ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
    7. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
    8. Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
      NOTE: You might have to press firmly to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
    9. Close the top cover of the product. The product restarts and then prints an alignment page.
    10. Click on setup on the printer select tools and select clean printhead.
    11. inside the printer clean the metal carriage rod,rollers and that is it (clean with moist cotton swab)
Jun 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black ink not coming through
I had the same problem. Ended up replacing the black/yellow "printhead" and that corrected the problem.
Jun 08, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Ink cartidges practically full but printer says they need replacing
Sometime the ink dry if you do not use it.....Try this :
Put warm water on a soft clothe and gently press the clothe with the printhead you'll suppose to see ink on your clothe. That's the better way to clean a printhead.
DO NOT SCRATCH THE PRINTHEAD WITH YOUR CLOTHE..
Mar 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
How to clean printheads
There are two things that you can do...
Clean printheads, because of ink buildup, or clean the heads and contacts because of debris buildup.
  1. Clean the printheads; this is done when there is streaking in the printout
    1. Press Menu
    2. Press 7 (Status Maintenance Menu)
    3. then 2 (Clean Printheads)
    4. Check print out. If it's still bad, then replace the printhead that's not working.
  2. Clean the ink cartridge contacts
    1. Using a clean lint-free cloth, distilled or filtered water (no tap water)
    2. Open the print-cartridge access door
    3. After cartridges are in center, unplug unit
    4. Remove the cartridges
    5. Examine contacts for debris buildup
    6. With damp cloth clean any debris buildup on cartridge or in cartridge bed
    7. Repeat for others
    8. Replace all and turn on printer
    9. Message will appear to Re-align heads, press enter to do this
If this helped, please rate FixYa!, ThankYa!
Dec 01, 2007 | HP OfficeJet D135 All-In-One InkJet...
Lexmark Impact S305 Wireless All-in-One Printer w/Copy/Print/Scan Logo
218 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
