Question about JVC Televison & Video
JVC LCD TV CAN DISPLAY GREEN, BLUE, RED, YELLOW COLOURS, BUT THE PICTURE QUALITY IS NOT GOOD IN TERMS OF COLOUR, IT LOOKS NEGATIVE (SEPIA)
I OPENED IT AND THERE IS NI PHYSICAL DAMAGE SEEN, EVERYTHING IS INTACT, NO BURNT PARTS, NO BULGED CAPACITORS
    Top Expert:
  • JVC Master
  • 75,599 Answers
Loss of Luminance signal. Actually this fault is related with its main board. Contact any service technician.
Gopakumar Gopalan Google
Posted on Dec 09, 2014
  • 92 Answers
SOURCE: westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Posted on Jun 22, 2009
  • 108 Answers
SOURCE: the colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Posted on Aug 30, 2009
panchal643Ja
  • 243 Answers
SOURCE: LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Posted on Jan 19, 2010
TODDAS
  • 431 Answers
SOURCE: I have a 32" AOC Envision L32w761 LCD hdtv with no
need to ck for your 24 volts going to your inverter board if missing ck power supply
Posted on Oct 07, 2011
RNS-Systems
  • 120 Answers
SOURCE: Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Posted on Feb 18, 2012
HOW DO I FIX THE DISPLAY OF JVC TV? IT SHOWS PICTURE BUT THE COLOUR IS BAD. I HAVE DONE SEVERAL COLOUR SETTINGS WITH NO RESULT, DURING THE ADJUSTMENT, THE PICTURE CAN TURN TO SEPIA GREEN, SEPIA BLUE E
This sounds like a bad cable or connection. Swap out the cable with a known working one and see if that helps. Next, wiggle the cable nearest to where it connects to each device and see if that recreates the issue. If so, your cable either has bad ends or your device has bad ports/connectors.
Dec 06, 2014 | JVC Televison & Video
How do I hook up my dvd/vcr to the tv
On the back of the cinavision you have two groups of sockets. The yellow socket under Video out is picture. Red and white is sound. Connect them to the TV's yellow red white sockets marked Video In 1. This connection will give you picture and sound from either the VCR or the DVD deck.
There's a better picture quality available for DVDs only from the Component video out sockets (green red blue). Next to them is another set of audio sockets (red white). Connect all five sockets to the TV's input number 2. The colours match up. The picture from Component will be clearer and sharper.
On your Sharp TV remote, select Video 1 to watch VCR, and Video 2 to watch DVDs.
Nov 07, 2014 | Sanyo DP39842B 39" 1080p LCD TV...
Philips 42PFL7962D/12 LCD TV
Try changing the Tcon board, this kind of issue is almost always caused by a bad IC on that board..If you typed in the right model number it may be hard to find this board as I couldn't find one...good luck!
Dec 17, 2017 | Televison & Video
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
RCA F31317 lost blue in picture.
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Feb 14, 2007 | RCA F31317 31" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
